Old 03-13-2010, 02:47 AM   #21 (permalink)
rusty - '00 ford mustang coupe
90 day: 24.31 mpg (US)
cbr929 - '00 honda cbr929 fast
90 day: 39.54 mpg (US)
Porshe - '06 Kawasaki zx10r
90 day: 47.21 mpg (US)
truck - '96 ford ranger
90 day: 26.51 mpg (US)
Originally Posted by MARTINSR View Post
Are you saying you would need to monitor the fuels heat and "adjust" it accordingly to work?
Really guys, this is so darn interesting to me, I never thought about it but everything you have said makes perfect sense!
Brian
Well you want to keep fuel at a certain temp, you don't want fuel to hit boiling point cause than it might start doing all kind of crazy stuff.
Old 03-13-2010, 07:41 AM   #22 (permalink)
Since the average engine tosses 2/3 rds of its heat energy away, that is where you will make the most dramatic improvement in efficiency.
Direct high pressure injection seems to tbe the way to go, with pressures approaching 20,000 PSI and beyond, you can really heat the fuel up without fear of boiling. In fact in the linked reference, it looks like the way to go is to heat and pressurize the fuel to the point where it will almost auto ignite without any compression. It may even go to the point where you use the exhaust heat energy to compress the air, instead of using the piston.
Guaranteed the days of the throttle restriction are just about over. Orbital was working on that. I notcied the OPOC engine is now using an electric supercharger. I look at it like my VX which used lean burn to essentially make the engine run in two parameters.
Normal for power
Lean burn for economy
I would love to see the previously linked setup on my VX
regards
Mech
Glossary Take II SVOboy Forum News & Feedback 50 12-29-2022 08:09 PM
Canada's top fuel efficient cars (by class) for 2010 MetroMPG General Efficiency Discussion 3 05-09-2011 01:56 AM
Efficient Engine Design ??? pgfpro EcoModding Central 110 02-12-2010 01:53 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
