Old 12-05-2011, 06:24 PM   #1 (permalink)
ODB2 question
I have a '97 Ranger with the 3.slow V-6 and 5 speed.
If I am not mistaken, that means it is ODB2. i seem to recall reading somewhere that all ODB2 engines use FI cutout when coasting in gear.
Am I correct?
I ask because my Ranger sure as hell does not implement it.
I can be coasting down a hill, in gear, with the engine well above idle speed and shut down the ignition with a very definite difference in engine drag.
If the engine was using FICO, this would not be the case.
I have read other threads here about wiring in a manual FICO switch.
Is this a good idea? Will I open other cans of worms in doing so?
Old 12-05-2011, 09:59 PM   #2 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Hi Pete,
Yes, your '97 Ranger is ODB2, but no, not all ODB2 engines use FI cutout when coasting in gear.
My '06 Scion xB has deceleration fuel cutoff. My wife's '06 Hyundai Elantra doesn't have DFCO.
I have wired in a manual FICO "kill" switch. It works well, as long as you're aware of and willing to take the risks of driving with a dead engine.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 12-05-2011, 10:07 PM   #3 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
My parents have a 1998 ford ranger, but it has the smaller inline 4 engine and it does cut fuel while going down hills, but it's rare, has to be fully warmed up, engine going fast enough and then I'll see the scan gauge hit 9999mpg.
Old 12-05-2011, 10:27 PM   #4 (permalink)
Pishtaco
SentraSE-R's Avatar
My xB enters DFCO with the engine warmed up and in gear with rpms >1500 rpm (>35 mph in 5th gear). My '02 Nissan Sentra had to have rpms >2500 rpm (>65 mph in 6th gear) to enter DFCO. Basically, my Scion uses DFCO all the time, and the Sentra hardly ever does.
Darrell
Old 12-05-2011, 11:50 PM   #5 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Question 1991 F-250 fuel cut off 302 5-speed
Rigged up a heavy duty switch on the fuel injectors power wire. Also have a heavy duty rheostat in that circuit to vary the voltage to all the injectors.
The resistor value is about 0 to 50 ohms. Have to turn it to 0 ohms to start it cold then can turn it up towards 50 ohms after its warmed up to lean it out. I know it's brute force but i've gotten 19 MPG on the highway by doing this, and putting a check valve in the vacuum line to the fuel pressure regulator. This is OBD-I stuff. OBD-II might be too smart for this to work.
I keep engine braking to a minimum because it's still braking.
Old 12-06-2011, 09:57 AM   #6 (permalink)
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
do you have an AFR guage to watch? and what ratio do you stop at?
Old 12-06-2011, 07:05 PM   #7 (permalink)
MP$
Sometimes I watch the voltage from the O2 sensor to see if its staying below the crossover. (not going into close loop). Also optimize vacuum. But mostly I lean it out until it loses power. I have not been able to melt anything, it just loses more and more power as I lean it out. The pipes are burning gray to white. Scan gage type testers wouldn't work because pulse width actually increases as the injector can't open fast enough to satisfy the fuel tables.
Old 12-06-2011, 10:25 PM   #8 (permalink)
OBD2 really only means that it has the plug under the dash that communicates via a very specific protocol. It doesn't necessarily say anything about how the engine management works under any particular circumstances--it really only means that you can plug in a single type of tool to find out what is going on.
-soD
