Originally Posted by eco_generator
Honestly the title should be changed to "EcoModders Average a reported 33 MPG, 25% over EPA"
I have seen quite a few highly suspect fuel log numbers and some that admit they only post ECO tanks. But I do agree the numbers are a lot higher than the average driver, who thinks hitting the EPA numbers is a myth and sham.
Shouldn't matter, the EPA numbers aren't lifetime averages, either. They're "first case basis", perse. They take the average of a few runs under "controlled" conditions, then post up the number. That's basically how any tank that goes into a fuel log is put in, unless the entire tank was highway, all in one trip.
Since most of us are working on tank averages during fill ups, each tank gives a somewhat accurate average account of the fuel used, allowing for +/- 10% Variability, approximately.
That would mean that even the "best tanks" are still averages, they're just not averages that are averaged into the other averages to make a lifetime vehicle average. (That's a hyper-average number of times to use the word average in a sentence.
