Old 09-21-2008, 05:24 AM   #11 (permalink)
CAUTION: May Stink!!!
BlackDeuceCoupe's Avatar
BDC's Honda CiViC HX/Si - '98 Honda CiViC HX/Si (HX Shell/Si Swap)
90 day: 40.56 mpg (US)
Send a message via ICQ to BlackDeuceCoupe Send a message via AIM to BlackDeuceCoupe Send a message via MSN to BlackDeuceCoupe Send a message via Yahoo to BlackDeuceCoupe
Originally Posted by bgd73 View Post
Ideas like yours are excellent and never bad opinioned by my own experience of unbelievably miraculously impossible running engines according to a gook with 50psi injection and "not enough".
Heh!
Child's play...
2008 Ford injectors went from 26,000 psi to an estimated 34,000 to 36,000 psi!
PickupTruck.Com - 2008 Ford Super Duty Spy Shots
.:: B16A2 HX/Si Coupe | '98 HX shell with full '99 CiViC Si swap | 40+ MPG
Listen to the people who fail. They know what they're talking about!
Old 09-21-2008, 07:28 AM   #12 (permalink)
'El Misil' - '91 Opel Calibra 2.0i
Last 3: 29.02 mpg (US)
Injection is satan.
If you are in need of an exorcist, the 'Bosch Church of Latter-day EFI' has some good ones, very hardened in the battle against the malign .
Old 09-21-2008, 10:12 AM   #13 (permalink)
How would you get the carbon canister and vapor recovery system to work? The purge system operates at negative pressure.
Old 09-21-2008, 01:42 PM   #14 (permalink)
Could a PWM voltage regulator be used to reduce the voltage to the pump? With the proper control circuit, the voltage could be further reduced at idle and increased at high load.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 09-21-2008, 02:11 PM   #15 (permalink)
NiHaoMike,
That is common on fuel systems in newer cars.
Dave
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
Hydrogen Generator Experiment willy57 DIY / How-to 601 08-23-2016 05:53 AM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 09:24 PM
Fuel Pump cut off trikkonceptz EcoModding Central 13 05-08-2008 03:25 PM
