Old 05-18-2012, 01:15 PM   #11 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Can't find it online as they shield their articles from non-members, but I do recall a local consumer group claiming the results are not equal across the car market.
In their tests, some brands responded better to the improved fuels than others.
The test cited above was carried out on a dyno, not on the road.
Old 05-18-2012, 04:41 PM   #12 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
IN finland you can get Neste green diesel which cetan value is 54-56. (lupo will be tuned for that stuff... On regular diesel it is 50-51 range in Finland. That green diesel has more biodiesel (NExBTL) which cetan value is higher.
on 100% NExBTL diesels cetan value is between 70-90 but it has less energy density.
You will get the benefits og higher cetan if your car has learning ECU otherwise there will not come much gains.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 05-19-2012, 04:17 PM   #13 (permalink)
...beats walking...
...similar results occur with octane in gasoline engines--*if* the injectors are too small, the ECU might not be able to "adjust" the fuel injection pulse width enough to utilize the higher octane of E85 fuels, etc.
