12-07-2014, 09:17 PM
#21 (permalink)
On ebay you can buy something for almost 100 bucks thats a box with some flashing led lights and a hand full of 8 gauge wires you mount under the hood and to both battery leads. The tear downs shows its a cap inside. The wires basically help ground the stuff under the hood the cap helps to filter noise.
12-08-2014, 12:51 AM
#22 (permalink)
Absolutely!!! Thats why when you replace your bat with a cap you get such a jump in mpg.
12-08-2014, 01:50 AM
#23 (permalink)
I bought a 3 x 5 port cigarette lighter adapters and 10 fuel sharks to go into the cigarette lighter sockets, and I filled up the tank.
That was 2 years ago. 30,000ks since and I still don't need any fuel.
I tells ya, they work really good...
The Following 2 Users Say Thank You to toc For This Useful Post:
12-08-2014, 03:04 AM
#24 (permalink)
Why not do what I did? I bought a thousand fuel sharks, wired them all together and now I simply run my car's engine at idle and it produces fuel. Next month I join OPEC.
The Following User Says Thank You to markweatherill For This Useful Post:
12-08-2014, 07:49 AM
#25 (permalink)
Count me in!
The Following User Says Thank You to cowmeat For This Useful Post:
12-08-2014, 08:16 AM
#26 (permalink)
Rat Racer
Yeah- forget mining for Bitcoins, I'm switching to Fuel Sharks!
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following 2 Users Say Thank You to Fat Charlie For This Useful Post:
11-03-2018, 05:18 PM
#27 (permalink)
It is a bit after hours, but Jalopnik had a take on the Fuel Shark.
https://jalopnik.com/the-fuelshark-w...bul-1479542390
Subtlety. I freakin' crave it.
01-28-2019, 10:37 AM
#28 (permalink)
Originally Posted by stargrit
It worked for the GameShark,GM is uses something vaguely similar on their new cars to reduce alternator load at idle and thus boost fuel economy.
Originally Posted by Joenavy85
it worked for the GameShark for PS2
Originally Posted by gone-ot
...BELIEVE IT OR NOT, but GM is uses something vaguely similar on their new cars to reduce alternator load at idle and thus boost fuel economy.
Oh what a smart bot you are.
And one minute later - gone! That was fast!
Reason: While I was typing mods were weeding!
