Old 12-23-2021, 02:55 AM   #1 (permalink)
Full economy hardcore listing
Hello
Toyota Yaris Mk3 1.0 3 cylinders 69 HP 2012
Toyota what android application for economic driving Via bluetooth elm327
Has anyone picked up the eco soft engine settings what is worth toyote Yaris
My result is 750 km on the tank city
Where can I find the economical driving results and driving techniques results list for the Toyota Yaris mk3 mk4
Old 12-23-2021, 07:36 AM   #2 (permalink)
Aerospyder - '00 Toyota MR2 Spyder
90 day: 41.98 mpg (US)
Simme - '83 IFA Simson Suhl S51
Motorcycle
90 day: 76.59 mpg (US)
There are different usefull applications, the app "torque" is quite versatile for showing data and diagnostics codes.
However it can not change settings on the ECU.
As for driving techniques, this forum lists quite a few in the wiki as well as a few simple and complex mods to get better fuel economy with your car.
Old 12-23-2021, 08:04 AM   #3 (permalink)
I have the Torque application
Which clocks are the best parameters to set for economical driving
Can you help find the fuel consumption results for Toyota Yaris 3 Cylinds 1.0
Old 12-23-2021, 08:46 AM   #4 (permalink)
Motorcycle
I would reccomend the momentary fuel consumption as well as either engine load or MAP gauge.
Even though the fuel consumption shown on the gauge might not be accurate, it helps you to figure out when you use more or less fuel.
If you want to compare your results with others, I reccomend the Spritmonitor app/website.
https://www.spritmonitor.de/en/overv...=2&powerunit=2
Old 12-23-2021, 10:11 AM   #5 (permalink)
Thanks
specify which clocks are set or the android application specifically for fuel economy.
How to find record-breaking users and ask them how the cars are prepared and what driving technique
Old 12-24-2021, 04:43 PM   #6 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
https://ecomodder.com/forum/emgarage...=Search+Garage
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
