Old 02-20-2014, 12:14 AM   #21 (permalink)
I wonder how much the carbon fiber trailer weighs vs. conventional?
Old 02-20-2014, 06:47 AM   #22 (permalink)
The article says it saves about 4000 pounds.
Old 02-20-2014, 08:28 AM   #23 (permalink)
The turbine shown in the video is a Capstone unit. It will be interesting to hear more about the battery pack and the electric drivetrain.
Edit: someone on CleanMPG found some more information:
http://www.examiner.com/article/walm...-trailer-truck
Powering this technological tour-de-force is a Capstone Turbine engine coupled to an electrical powertrain. ... Their light weight, small size, and quick starting time make them ideal as "instant-on" backup power to recharge the main batteries. An example of a hybrid vehicle is the Capstone CTM-380, with a 30 kW gas turbine generator running on diesel, that recharges Li-Poly batteries when necessary. The CMT-380 has a proposed range of 80 miles on battery alone, but when combined with the micro turbine that range is pushed to over 500+ miles.
Xist (02-21-2014)
Old 02-20-2014, 08:59 AM   #24 (permalink)
Sparky - '14 Chevrolet Spark 1LT
90 day: 45.71 mpg (US)
Will there be enough fuel saved to cover the cost of a at least 2 sides of 53' carbon fiber per truck?
Old 02-20-2014, 10:06 AM   #25 (permalink)
The concept is of course the ultimate expression of "what if" and "why not", but as usual production models will surely be less glamorous.
I suspect something like fiberglass, aluminum or a composite like Monopan could easily be an affordable substitution for carbon fiber.
MonoPan :: The Future in Material Technology
Neil (and Rustylugnut), thank you for providing all of the hybrid information, I missed this on my first skimming of the article.
Old 02-20-2014, 10:11 AM   #26 (permalink)
For a comparable, although I'm not sure how close, I offer this quote below.
MonoPan :: About MonoPanŽ
Greater Payload with Vehicles
You can improve your payload ratio at will with the MonoPanŽ body assembly. You can transport up to 70% more payload (approximately 600kg in comparison with a 3.5 ton vehicle with a body assembly made of plywood). This means that you can carry almost 1500kg of freight with a 3.5 ton truck made of MonoPanŽ. Whereas you would need a 7.5 ton truck of conventional construction for the same payload.
You will want a trailer material which will not show/telegraph interior dents, creases, and scratches. Some impact strength from blows caused by loading will also be favorable.
A double wall composite or honeycomb makes a great deal of sense to me.
I don't see where the CF trailer is listed as having a foam core, if it's a single skin with nothing else it's still going to need some hard points or frame I suspect.
Old 04-04-2014, 06:14 PM   #27 (permalink)
igo
igo's Avatar
Mini Box Truck - '05 Scion Xb
90 day: 32.87 mpg (US)
It FITs - '09 Honda Fit Sport
90 day: 36.2 mpg (US)
Impreza - '13 Subaru Impreza Sport
90 day: 30.92 mpg (US)
I just came across a video about this Semi on weather.com of all things! Was going to make a thread about it but, I guess someone already caught it.
I think it's a really neat design although I am a little skeptical about a carbon fiber trailer (mainly because of cost). The cab looks really nice.
