A timing belt change may destroy FE if the timing is offset during the process. One to look out for.
Does the engine run smooth when idling? An unfiring spark plug halves your economy and spoils performance.
How does it coast? (is it a manual or an auto?)
What happens when you put it in neutral, does it maintain speed or lose it quickly?
If the latter something's wrong with the tires, wheel alignment or drivetrain beyond the tranny. If it coasts fine the problem is ahead of that.
Raising tire pressure should help FE a bit. If it helps a lot, like more than 10%, then your wheel alingment is likely out.
