Old 03-22-2014, 02:24 AM   #1 (permalink)
is a gas system worth the investment?
hey misses is looking at getting a new car
should get about 10L per 100km on petrol
and about 14l per 100km on gas
petrol is around $1.60 per liter
gas is around $0.80 per liter
gas system is around $4000..
so if i worked this out right
$16 per 100km on petrol -> 16 cents per km
$11.2 per 100km on gas -> 11 cents per km?
so it would save around 5c per km depending how she drives
how many km's would it take to make up the $4,000 outlay :/
if i could get her to average 7 - 8l per 100 would pretty much be the same, but thatll take a bit of time with her lead foot haha
Old 03-22-2014, 03:01 AM   #2 (permalink)
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
Gas = petrol
You must not be talking about gasoline vs petrol.
The answer is 80,000 km before you save any money. How many km do you average per year? Are there any significant maintenance requirements that would increase/decrease the cost?
1998 Honda Civic HX - My Project Thread
Old 03-22-2014, 03:03 AM   #3 (permalink)
The Rental - '13 Hyundai i30
90 day: 37.55 mpg (US)
Autocross - '04 Ford Focus ZX3
90 day: 24.76 mpg (US)
The Wifes - '02 Ford Focus SVT
90 day: 23.54 mpg (US)
i think he means CNG or propane
The Following User Says Thank You to Thenorm For This Useful Post:
Cobb (03-22-2014)
Old 03-22-2014, 03:15 AM   #4 (permalink)
oh sorry LPG, just use to calling it "gas"
umm averaging about 15,000 per year
from what i can tell / heard lpg has more wear and tear on the engine
Old 03-22-2014, 03:28 AM   #5 (permalink)
Mazda 626 - '80 Mazda 626 Base
Over here LPG is a common conversion that pays off. Our gasoline/petrol is more expensive though.
If an engine is designed for LPG, it can outlive a gasoline/petrol engine. The propane/butane mix is a vapor when it enters the engine, and vapors don't really wash the oil off the cylinder walls.
If you were running an older car that was back when cars had distributors, the conversion would be relatively simple to make the car run optimumly on LPG. You'd want a cam that is for torque, raw torque, not high rpms. If I remember correctly, the big deal was with the "lobe separation", not the profile of the actual lobes. If I remember correctly, you'd also want colder spark plugs, and the ignition timing should be advanced somewhat because LPG has a higher octane rating. Ideally, if running straight propane, the compression ratio should be something like 12:1, though it should be somewhat lower if running propane/butane (LPG that most filling stations have).
$4000 is really expensive for LPG. Around here a high grade LPG system would cost aout $1400 AUD or so. We don't use CNG except for on busses. I could get a fully approved LPG system for a carburetored engine (without any lambda sensor) installed for about $400 USD with everything. Tank, reducer, hoses, wiring, valves, fill up tube, etc.
As for more wear on an engine, that is possible if using gas on a gasoline/petrol engine that does not have hardened valve seats i.e. was designed for leaded gas.
I don't think a new car is intended to run on leaded petrol...
Old 03-22-2014, 03:37 AM   #6 (permalink)
the car is a 2012 fg xr6,
they do come in a straight gas but decided against it, was going to install a dual fuel
but yeah $4,000 is installed..
would be nice to get it cheaper but just not going to happen over here..
not sure about a carbie system but yeah no carbie anyway
but yeah doesnt look like its going to be worth it on this car, though might have a project car thatll need it haha
