Old 11-06-2008, 09:03 AM   #1 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
GDO range of operation
As I'm doing my last EOC on the way home, I'd like to coast all the way into the garage. If I'm lucky (and with a new battery), sometimes my GDO will activate far enough away that I can slip under the door as it's still going up. But it's too close for comfort.
Anyone know how to extend the range of a GDO?
Extending the antenna to the outside would probably help, but I think I'd have to use shielded coax. I don't want to change the effective length of the antenna wire, right?
I need about 350 feet of range.
-Terry
Old 02-10-2009, 09:49 AM   #2 (permalink)
Deadly Efficient
anyone?
anyone?
-Terry
Old 02-10-2009, 09:54 AM   #3 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Have you taken apart either the transmitter, or the receiver to see what sort of antenna is on either end?
If you are lucky the receive end will be an F connector with a stubby antenna attached, then you could extend that out . . . ..
Edit: if you always approach from the same direction you could consider a reflector behind the unit, sort of a low tech dish arrangement . . . .. .
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 02-10-2009, 10:08 AM   #4 (permalink)
Deadly Efficient
I'm pretty sure the receiver antenna is just a wire hanging out, but I'll take a closer look tonight.
The reflector idea would be easy to try. What would work, aluminum tinfoil?
-Terry
Old 02-10-2009, 10:28 AM   #5 (permalink)
EV OR DIESEL
Tinfoil would be easiest, at least temporarily . . . .
Do we know what the operating frequency of the system is?
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Old 02-10-2009, 09:29 PM   #6 (permalink)
Deadly Efficient
This is the receiver mounted on the ceiling of the garage.
It says 'freq. 390' on the side of it.
this is the guts of one of the tx's. The white cylinder with the wire wrapped around it is the antenna, right?
-Terry
Old 02-28-2009, 01:07 PM   #7 (permalink)
Deadly Efficient
I made a quick 'n dirty reflector with tinfoil stuck to part of a cardboard box.
I walked outside with the opener to test for range. It stopped working when I got about halfway along the divisional island at the entrance of the subdivision. That's about half of what I'd really like. So it's showing promise.
-Terry
Weekend in the Toiyabe Range... jamesqf Success Stories 2 10-01-2008 11:15 PM
Bearing wear and low RPM high/load operation. roflwaffle Off-Topic Tech 3 08-14-2008 04:36 AM
Would a different heat range of spark plugs help FE? Chris D. EcoModding Central 3 03-17-2008 08:03 AM
electric caravan 300 mile range oldschool Fossil Fuel Free 0 01-08-2008 06:29 PM
