Originally Posted by Daox
I'd probably just go with the quality (rubberish stuff, not plasticy stuff) hot water pipe insulation. Its cheap and should hold up to the temperature it'll see.
Always check the "flammability" ratings of ANY non-automotive insulation(s) that you want to use...some will *melt* when gasoline/oil get on them; others, are temperature volatile (melt) at under-hood temperatures (engine blocks ~ 400ºF).
