Go Back   EcoModder Forum > Classifieds > For Sale
Old 08-28-2009, 10:04 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
WTB: CRX HF/Civic STD knuckles in NJ
Anyone got some or know someone? I can get some from Topher but the distance would require shipping and I'd like to avoid that to keep expenses down.
Thanks!
Old 08-29-2009, 06:46 PM   #2 (permalink)
VEEP
CRX HF/STD knuckles
Are you looking for a set of HF knuckles, specifically? I only recently found out that the HF knuckles differed than those found on the DX/Si models due to spline count. Anyway, I just wanted to be sure you knew what you were asking for.....b/c I thought your car was a DX....originally (before your swap).
-Brian
Old 08-29-2009, 06:52 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Yep, specifically. The Insight axles have the same spline count as the hf/std axles, so that's why I want the HF/STD knuckles.
Old 08-30-2009, 10:40 AM   #4 (permalink)
VEEP
CRX HF knuckles...
Well, I've got a set. What did you do - blow a wheel bearing? I've got a set (passenger's & driver's) that I've been saving for the inevitable "rainy day", but I've yet to use them. Both have new ball joints, and I think the wheel bearings were replaced in them when all of this work was done - the upper control arms & all associated bushings & hardware is also new. This is on both of the aforementioned knuckle assemblies. I left everything attached for now....one of them still has the control arm connected, so really everything is there and ready to install....but I didn't know if I really wanted to let these ones go, since they were all set up and ready to roll. Not trying to be a jackass, just thinking aloud here. I still have the current set on my daily driver HF ('89). Would you be interested in those? I suppose what I would then do is swap in the newer ones that I've had just sitting around. I'm just one of these finicky people who doesn't like to be without a backup. Let me know your thoughts on the matter....I'm in central New Jersey....Exit 11 off the Turnpike, then GSP-123 to Route 9. I'm also about 25 minutes from exit 9 (turnpike)....or about 30 minutes from exit 8 or 8A (turnpike). I'm about 35 minutes from Great Adventure...seeing as how you're southwest of me.
Old 08-30-2009, 01:18 PM   #5 (permalink)
Dartmouth 2010
SVOboy's Avatar
Basically, I need them so that I can use Insight axles, which seem to be have identical hub-side splines to the HF/STD axles...
How much would you want for them? I don't want to put you out, since topher can send me a set. I've just been trying to avoid shipping.
WTB: Honda CRX any year pref automatic/please help novastar83 For Sale 3 05-31-2009 03:19 PM
WTB 84-87 CRX fenders Christ For Sale 0 12-02-2008 11:43 PM
