It gets worse
Hmm, not too late for me to change careers. $33/hr currently, but if demand exceeds supply of workers, that price can't hold.
Why would you need a journeyman to fix a charger?
Couple places I worked, the techs were trained to follow a certified process which negated the need for high skill. If they ran across something really intricate/difficult, they called home to the help desk. Worse case; back in the day, IBM evolved to board swapping until it was fixed. If it was really fubar, they replaced the whole unit. |
'electricians'
406- trainees per year, per each state of the republic. Obviously 'impossible.' -------------------------------------------------------------------------------------- In 1976, during a college field trip, I visited a local manufacturing facility which used computer-aided machining. If anything went 'wrong' with the equipment, the operator dialed the phone number of the milling machine manufacturer back east. The computer on the other end of the line diagnosed the problem, and sent a message, instructing the operator to change out a particular plug-in circuit board ( of which the factory held in inventory ) to bring the machine back online. The 'multimillion dollar' mill was back in service within minutes, and never required anyone with more than a high school education to 'fix' it. In the present day of 'over-the-air' updates 'n such, I don't see a problem. |
Right now I work about 2 days out of 5 for about $35 an hour so not that interested in being an electrician unless it's for my self.
Aptera and Xbus look better every day. The best plug is no plug.
Easy gigs bore me to death and I grow to despise them. Doesn't matter if I'm getting paid a ton to do something that doesn't challenge me. Electricians don't have an easy job. They crawl on their bellies through puddles of water under houses, and tiptoe in rafters in 130 degree attics. It's work to be proud of though, because one has endured the situation and made a thing better afterwards. Quote:
Cant see where they install this stuff in hard to access places. No crawling around under, over or hard to get to. Federal and universal muni Code requires power turn off within 6ft, so it's not a shock hazard. Only major requirements could be some sort of lifting device. Everything else is plug and play with sealed modules because you dont want your service people poking around the innards. Worse case the repair person needs a weeks training doesn't need the 36 weeks electronics course I required for servicing nuke missiles. All the techs I see lately have pictures and instructions they watch on their phone.
So I stand on my original comment regarding service. Ain't rocket science, and I am qualified to determine that. |
