Old 12-15-2009, 09:23 PM   #1 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
Aerodynamic mods on the "Tank"
So since i've gotten the car i've been slowly improving my fuel economy but i want more
Deleting the rear piping after the stock muffler and putting a turndown saved 10 pounds
So now it's only 4490 instead of 4500 pounds
but i still have horrible aerodynamics so i need a few ideas to help this
I'm already planning on lowering my El Camino and putting a tonneau cover on it so those are automatic mods. Sorry i'm not doing flat wheel covers I would put skirts if i could find them for my year el camino though.
Anyone have any more suggestions?
I want to do a flat underbelly but don't know how that would work with this car
Old 12-15-2009, 09:46 PM   #2 (permalink)
Why the exhaust mod? Cutting the piping and letting the exhaust out earlier could allow more fumes into the cabin, killing you with carbon monoxide.
Old 12-15-2009, 09:57 PM   #3 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
For serious weight reduction, give it EcoTec power. You'll even gain an OBD-II port for your ScanGauge.
For that matter, give it VTEC.
Old 12-15-2009, 10:00 PM   #4 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I've actually got a spare EcoTec motor that needs a timing chain and a head gasket...
Old 12-15-2009, 10:01 PM   #5 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
I doubt you will find a manufactured skirt fer the El Camino. Yer better off fabbing something on yer own.
How much effort/money/time you looking to put into this as a project? Simple things could be just grill block. Start out basic and work from there...unless yer paying someone else to do it fer you...
Old 12-15-2009, 10:21 PM   #6 (permalink)
You know i've actually seen a few 64-65 Elco's with shirts so i figure SOMEONE does it
and if you look in the garage you'll see i'm planning on spening ALOT on this car it's my first car so i'm keeping it forever
my plans are a 800 HP duramax that gets over 30 MPG freeway.. should be fairly easy with this car
Old 12-15-2009, 10:22 PM   #7 (permalink)
Be careful you don't over-oil your K&N.
Regarding aero, take a piece of rope that can be easily seen, tie it to your front bumper, up and over the highest point of your cab, and down to your back bumper over the tailgate, then snap a digi of it.
Upload the pic here, then check the angle of the string in the pic compared to the ground. I'm fairly certain your cab/tailgate angle will be sufficient to just add a frame and some sheets of coroplast for an aero-cap without too much thought invested. Might be good for a decent gain.
(Try to test it somewhat scientifically, though...)
The Following User Says Thank You to Christ For This Useful Post:
Domman56 (12-15-2009)
Old 12-15-2009, 10:24 PM   #8 (permalink)
Dumped it at the rear axle i didn't just cut it and leave it open at the muffler, It's a turndown so really the only time it'd be dangerous is if i commuted and sat in traffic alot.. which i don't , but i know what you're talking about that's how it was when i had straight pipes
Old 12-15-2009, 10:25 PM   #9 (permalink)
Is it a V6 ECOtech? I'd actually consider that
Old 12-15-2009, 10:29 PM   #10 (permalink)
Oh i know better than that that's the only way i've seen them be harmful
Yeah I'll try that
I had a flush mounted campershell on it but i prefer the look without it
GM mods the Sierra hybrid pickup: aerodynamic tweaks + LRR MetroMPG EcoModding Central 5 09-03-2012 08:17 AM
Suggested Aerodynamic Mods for a Cobalt stevey_frac Aerodynamics 90 03-28-2012 10:17 PM
Large Pickup Aerodynamic Mods buckyball Aerodynamics 43 08-02-2008 05:49 PM
[article] 5 Real DIY Aerodynamic Mods Detroit Can Add for MPGs in '09 SVOboy Aerodynamics 15 07-01-2008 01:57 PM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 07:46 AM
