Old 10-03-2011, 08:51 PM   #1 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
question on Clutches ?
can a used clutche affect the fuel economy? (used like need to be change soon (not very soon))
Old 10-03-2011, 09:01 PM   #2 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 41.21 mpg (US)
If it's slipping, yes.
Old 10-03-2011, 09:07 PM   #3 (permalink)
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
What are the signs and simptoms that you notice about the clutch?
Old 10-03-2011, 09:18 PM   #4 (permalink)
40-60-40 MPH P&G
a little slipping some times and wierd sounds some times but no problem with the 4 and 5 gear
Old 10-03-2011, 09:53 PM   #5 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
If it's weird sounds that happen in some gears but not others then you might have a transmission bearing that is going out, try replacing your transmission fluid? if your clutch is slipping tho not all of the energy is getting to the wheels so yes, it is costing you gas.
Old 10-04-2011, 12:37 AM   #6 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
A slipping clutch will show it most in top gear. Your description is the opposite.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 10-04-2011, 01:08 AM   #7 (permalink)
40-60-40 MPH P&G
maby i dont feel the slipping in top gear. but i recently made a trip of 140 km that i am used to do and a got a average of 4.05l/100km and about one month ago i did the same trip and i got 3.6l/100km dont know if its the clutche?
Old 10-04-2011, 02:07 AM   #8 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Hard to say, but could it be related to the cooler temperatures we have had over the past week or so ? There are so many factors than can have an impact on fuel consumption.
Old 10-04-2011, 09:19 AM   #9 (permalink)
Ryland's Avatar
Replacing the transmission is not much more work then replacing the clutch, so if you are already prepared to do the clutch you might just do both.
A bad bearing in the transmission is going to give you poor mileage as well, if it's the main bearing then it could be leaking fluid on the clutch causing it to slip.
Old 10-04-2011, 09:30 AM   #10 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
Are you running out of pedal travel upwards after the clutch has engaged?
The Following User Says Thank You to jakobnev For This Useful Post:
backsidesnap (06-02-2012)
