02-17-2014, 01:43 PM
Master Ecomadman
Tire Sipe
- Tony
02-17-2014, 02:08 PM
The Dirty330 Modder
Originally Posted by arcosine
I would watch this although siping tires is good for snow and wet surface traction if the outside lugs are siped and you get into a rocky terrain it will destroy the siped outer lugs
i guess the article was for snow so it would be fine
"The only real mistake is the one from which we learn nothing."
- Henry Ford
02-17-2014, 03:47 PM
More sipes == less contact area on the ground, more tread squirm, less dry traction. Generally more noise as well. Probably slightly higher rolling resistance.
It can help on wet roads or snow and ice--IF you know what you're doing. (Hint: Tire manufacturers have spent many man-years figuring out what works.)
It's not anything I would even consider doing to my own tires. Nor would I want to try hand-siped tires from a local tire shop, unless the person doing the cutting has many years of experience doing just that.
-soD
02-17-2014, 07:07 PM
Master Ecomadman
I'd do it to my tires. You California guys don't have snow.
- Tony
02-17-2014, 08:44 PM
I love shaved ice!
02-17-2014, 09:17 PM
Master Ecomadman
Originally Posted by Xist
I love shaved ice!
Well, you need it in AZ.
- Tony
02-19-2014, 07:55 PM
Do more with less
Tony
I put snow or off road tires on all of my vehicles. Our road here is gone from snow to ice and now mud. I couldn't be safe with hi mpg tires. The money I would save on gas would be converted to tow or body work bills.
I haven't reset the ultragauge on my van all winter. Today was the first that I have seen 16.4 since December or early January.
– Noah Webster, 1787
02-19-2014, 09:50 PM
Les Schwab always advertised siping as a way to improve fuel economy by lowering rolling resistance. I'd be very surprised if it had that effect.
It's certainly a good idea for ice traction, but then again, snow tires come sipped from the get-go.
My recommendation is to get extra wheels and run the appropriate tire for the job. It's impossible to make a tire that excels in every performance category because most areas of performance are in opposition to the others.
02-20-2014, 02:52 PM
#9 (permalink)
Smeghead
-soD
I am curious how siping reduces contact area by any significant amount All the sipes I have seen are just slices through the tread block.
How does a smaller contact area reduce traction? Reduced area means more weight on the now smaller area, end result is amount friction is the same.
More squirm I get but is that a problem for a non performance driver?
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
02-20-2014, 02:58 PM
#10 (permalink)
Removing material from the tread block reduces the actual material that is contacting the ground at any one point. I don't know if just 'slicing' the tread on the tires without removing material is siping, but I don;t know much about this.
All the sports cars with wide tires to maximize contact patch are doing it wrong. They should be rollin on bike tires for max traction. Same with those offroaders and wide tires. This seems wrong, no?
