Old 11-12-2011, 01:27 PM   #1 (permalink)
Burtha - '90 chevy C-1500 W/T
Trying to rehabilitate my truck from its currently areo handicapped state
Ok, so I'm trying to rehabilitate my truck from its currently handicapped state into something that will not kill me on gas.
the specs are so:
Year: 1990
Make: Chevrolet
Model: C-1500
Trim: standard cab w/t (work truck)
Engine: 4.3l v-6 TBI
Trans: 3spd hydro-turbo 400
Drive train: F/R 2wd
Odometer reading: 200,xxx
Original avg mpg: 17mpg
Current avg mpg: 15mpg
Engine oil:5w-30 caster-oil edge syn W/ 1/2 quart lucas
Trans fluid: atf W/ 1/2 quart of lucas
Diff oil: ?????? (best guess is 80-90W)
Tires F: Master craft avenger g/t (P255/R70R15) 40% tread
Tires R: Good year wrangler A/T (P235/75R15) 100% tread (new)
Gas tank compacity: 40 gal
HP: 160hp
Torque (lb-ft): 235
Stock weight: 38xx
Add on's: 1990 ford camper (overlap 1" in front/ 2" in back squeezed 250-300 lbs best guess)
New parts:
heater coil/ egr solenoid/ egr valve/rear tires/ filters/ oil/ egr vacuum lines/ spark plugs/ coolant/ wipers/ spark plug wires/ egr and air cleaner gasket/ air cleaner/ trans vacuum line/ audio system/ gas cap/ R/P tail lights bulbs.
missing, broke or deleted:
a/c (disconnected)/air damn (broke/deleted)/ f/p fender (dented/ attempted to fix just ended up putting holes in it)/ interior light (deleted)/ thermostatic air cleaner valve (deleted/ because it was broke)/O2 sender (missing)
Old 11-12-2011, 01:47 PM   #2 (permalink)
Put a diesel and manual transmission in. Anything less is just fooling around.
Old 11-12-2011, 03:19 PM   #3 (permalink)
rehabilitate
Do you have some photos of the beast that we can cry over?
Old 11-12-2011, 07:39 PM   #4 (permalink)
need 4 more posts
Old 11-12-2011, 07:39 PM   #5 (permalink)
3more
Old 11-12-2011, 07:40 PM   #6 (permalink)
2more
Old 11-12-2011, 07:40 PM   #7 (permalink)
1 more
Old 11-12-2011, 07:41 PM   #8 (permalink)
ok pic time
LIST OF IDEAS SO FAR: (WAITING ON FUNDS)
1) a/c-DELETE
2) air damn- REPLACE
3) f/p fender- REPLACE
4) thermostatic air cleaner valve + air heater line- FIX/ REPLACE
5) O2 sender- REPLACE
6) catalytic converter- DELETE
7) strait pipe- install
8) clean under body of truck
9) headlight covers and a grille block in one piece of acrylic plexi
10) smooth hub caps
11) seal and smooth gap between cab and bed W/ rubber/plexy glass or duct tape
12) move thinner tires to front when i get new A/T for rear
13) strip and repaint truck then wax
14) under drive pulley
15) electric fan DELETE manual fan
16) replace gaskets for timing chain cover/ oil pan/ transmission oil pan
17) 195 thermostat replacement (OEM)
18) 700r4 transmission swap
some of those are more maint. than for getting better mpg but I'm using this list to keep track of stuff i need to do to
ANY OTHER LOW COST MID-RANGE COST IDEAS OUT THERE??
Old 11-12-2011, 07:43 PM   #9 (permalink)
why not just buy a new truck if I'm going to do that do that working with what i have man
Old 11-12-2011, 08:58 PM   #10 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
From what I've seen in the posts here, the big gains in pickup truck aero are in dealing with the air flow from the cab roof back to the tailgate.
If you can get by without the current cap, you could
- - Easy route: cover the bed with plywood sheeting or similar. Make the panels 3-1/2 feet front-to-rear. So you can remove them and lay them in the bed when hauling something taller.
- - More thorough route: Build a cap that tapers down towards the rear. Search this Aerodynamics forum for discussions on - "pickup cap", "aero pickup", "truck". Or just scroll down through.
Cleaning up the aero underneath is also worthwhile. Working under a truck is way easier than wiggling around under a Civic up on jack stands. Count your blessings!
Coast long and prosper.
