EcoModder.com
-   DIY / How-to (https://ecomodder.com/forum/diy-how.html)
-   -   Good Coroplast to Coroplast Adhesive? (https://ecomodder.com/forum/showthread.php/good-coroplast-coroplast-adhesive-3253.html)
garys_1k 06-22-2008 12:47 AM
I want to patch up some "oops" and bond some lap joints together. What's a good glue to hold this stuff to itself?
Daox 06-22-2008 09:24 AM
I'd give super glue a try.
metroschultz 06-22-2008 09:25 AM
I was wondering that very same question.
I was going to try using 3M spray trim adhesive (I have 2 partial cans on a shelf) That stuff seems to be able to hold just about anything to itself.
My other thought was to carry some coroplast to the craft store or home depot and ask them for advice.
And now a 3rd thought, asking the people who sold me the coroplast in the first place. They ought to know.
Shultz
reformed 06-22-2008 10:07 AM
I'd try liquid nails or possibly gorilla glue.
MetroMPG 06-22-2008 10:34 AM
I've used contact / rubber cement with coroplast (once). Worked well for me.
basjoos 06-22-2008 01:59 PM
Coroplast is made of polyethylene, so you need to use one of the few adhesives that will work with polyethylene, which is a low surface energy material that most glues will only attach weakly too. If you are careful, (since coroplast is hollow) you can also heat weld pieces of it together. McMaster-Carr sells an epoxy adhesive that works with polyethylene.
wagonman76 06-22-2008 02:13 PM
Walmart sells a 2 part glue (primer + glue) that says it works even with polyethylene. I know it is rare to find one that does work. Honestly Id try contact cement first, it seems like it would work a lot better for large surface area lap joints.
garys_1k 06-22-2008 04:24 PM
Thanks for the info. on just what coroplast really is, basjos. I found some information about bonding polyethylene by googling and found this writeup about a specialty 3M product, DP 8005:
http://www.stealth316.com/2-dp8005.htm
He talks about the special applicator -- I'd give just squirting it out on a piece of cardboard and stirring it up a try. It looks like it's available at "drillspot.com" here:
http://www.drillspot.com/products/32...astic_Adhesive
With ground shipping a single tube is about $25.00. I may want to live with my ugly lap joint for a while, or even try some really short sheet metal screws run in from the piece behind the visible surface to see it that's good enough for a while.
Edit to add: Sheesh, thanks again, basjos, for the McMaster-Carr reference. I'll see if the outlet near me stocks the stuff.
Meph 06-22-2008 08:48 PM
construction adhesive works well for most anything
ebacherville 06-23-2008 12:42 AM
you should try fiberglass resin on a sample piece.. bet it would work, there are different types of resins that are compatible with different types of materials..
Really i love fiberglass resin there are so many uses for the stuff.
