Old 11-24-2008, 04:56 AM   #1 (permalink)
NEWB!
D_Bat's Avatar
D_Diesel - '98 Volkswagen Jetta TDI
90 day: 49.91 mpg (US)
Send a message via ICQ to D_Bat Send a message via AIM to D_Bat
Just started! '98 Jetta TDI
I'm new to the board. I am finally getting a little out of my speed craze. I used to drive a turbo'd VR6 Jetta that got nearly 12mpg daily and now that I drive 140 miles round trip three days a week that had to go.
I bought a Jetta TDI that is getting an even 45mpg every tank with no mods and I'm hoping to up that fairly soon. I've gone through about six tanks now and I want to hit at least 55mpg, more would just be icing on the cake.
I do a lot of car work. I turbo'd my other car, have replaced almost everything from valve springs to brakes, to bearings, to transmissions and clutches, and to gas tanks. I've also fabricated up brackets and boost piping with my welder.
1999 VW Jetta Trailer
1998 VW Jetta TDI
1997 VW Jetta Project Car
Old 11-24-2008, 10:12 AM   #2 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Hi and welcome to EM!
140 miles round trip, you'll want a taller 5th. You have a .681 and a .658 to choose from. Gear is $350 + install, but you can always sell your TDI stock 5th for at least $100 to gassers looking for longer, but not too long, legs.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 11-24-2008, 11:15 AM   #3 (permalink)
NEWB!
D_Bat's Avatar
Yeah. I've been eyeing those for a long time. A long time being just as soon as I got it but haven't had the cash up front for the longer 5th. Here in Florida especially since all the roads are flat and the highways are set to 70mph. I think it's a 600rpm drop from what it is now with the new 5th which would put me around 1900-2000rpm at 70 which is darn near perfect. What have you done to get 60mpg out of your tdi?
1998 VW Jetta TDI
Old 11-24-2008, 12:45 PM   #4 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
100+ hypermiling / ecodriving tips to increase gas mileage - EcoModder.com
Cheapest thing to adjust is you
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 11-24-2008, 12:52 PM   #5 (permalink)
I keep the revs low, which without a taller 5th means driving slower.
Old 11-24-2008, 08:50 PM   #6 (permalink)
NEWB!
D_Bat's Avatar
Yeah. Most of those driving tips I do when I drive. Sometimes I am in a hurry and feel rushed and don't apply the gas saving driving but I'm doing better here and there. Most of the time I shift at 2k rpm, barely put the foot on the gas pedal, and leave it in gear and downshift without hitting the gas to slow down and slow down way before the light/stop. Not a whole lot I can increase as far as driving habits until I get one of those Scan Guages. That will show my bad spots. For highway I have recently been following about 50-75 feet behind semi's to catch their wind breakage and draft them. Mythbusters did a test and 100 feet behind they still got a gain which I'm sure you guys have seen. The best I've gotten is 45.9mpg. I know I can hit 46-47 for a whole averaged tank but that'd be the highest for a completely stock TDI with 0 mods and a mix between city and highway driving. I guess the mileage is about 1/4 city and 3/4 highway.
1998 VW Jetta TDI
Old 11-24-2008, 08:59 PM   #7 (permalink)
Red
Red's Avatar
Welcome to EM
Old 11-19-2010, 10:24 PM   #8 (permalink)
Silver Scrapper - '02 Toyota Corolla CE
90 day: 32.64 mpg (US)
In what little time I have been a diesel fan, I've learned of an interesting system that gives you better mpg as well as a little more power. It's called water/methanol injection and basically it increases combustion efficiency which equals more power and fuel economy. I think full kits cost around $600 and you can see a 20-30 hp boost along with a 4-6 mpg increase over your baseline. There's a trunk mounted tank you fill with the water/methanol mix and it's up to you when you want the system to be activated. I know it's a bit pricey, so i guess this is just something to keep in mind for later! Best of luck!
Jetta TDI Duct Tape Mods Sayyad Aerodynamics 31 09-22-2011 09:46 PM
Jetta TDI wins green car of the year award SVOboy EcoModding Central 0 11-20-2008 06:44 PM
Is VW lying to the EPA? Why does Jetta sedan / wagon have identical MPG ratings? MetroMPG General Efficiency Discussion 16 11-07-2008 04:39 PM
n00b here- 2001 Jetta TDI sharpfork Introductions 6 10-13-2008 02:36 AM
One more TDI...with a twist tasdrouille Introductions 5 01-22-2008 02:33 PM
