Greetings from Sacramento, CA
I have joined the group to discover ways to improve the fuel mileage of my 2019 Toyota Tacoma, 3.5L V6, 4WD.
Can you suggest a starting point of thread(s) for me to begin learning? I'm a huge law enforcement, K-9 Unit supporter. I have done volunteer work for years for many K-9 Units to help them raise money to protect and care for their current and retired K-9s. |
Is it still fitted with an engine-driven radiator fan like the overseas Hilux?
I don't know the answer to that.
??? How would I verify? |
Open the hood and take a look around the fan assembly, keep an eye for belts and pulleys, or if there is a larger gap between radiator and engine. Usually a more compact electric fan assembly would leave that larger gap, with the fan much closer to the radiator.
I can easily turn my radiator fan with just my hands and it has no belts, so it looks like an electric fan to me.
Ed |
No opportunity there.
ecomodder.com/forum/google_search_results....&q=tacoma+v6 About 158 results (0.13 seconds) |
Aeromods? (Sloping "camper shell")
2WD conversion? Automatic or manual? Would pulse and gliding work? Is there a diesel Hiliux that you could find a motor from and do a diesel conversion? |
Don't know if that is an option BUT manual disengage front hubs help as does skinny tires unless gou do mudding a lot. Opinions vary on skinny tires for mud. Hows THE APCD there for inspection?
What is "APCD"?
Ed |
