Old 09-26-2014, 10:16 AM   #11 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by ME_Andy View Post
I highly recommend this peelable caulk.
Hot glue works too, and if your engine gets really hot it might just melt off
Old 09-26-2014, 11:31 AM   #12 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
I highly recommend this peelable caulk......
Oooooo, And it's Vanilla Scented!!!
Seriously this is a great suggestion, I had never heard of this stuff before.
Aeroheads advice to make sure air has room to spread out behind the grill is great too. It makes a lot of sense if you think about it, but if it isn't considered, you probably wouldn't think of it on your own.
Also, when blocking a grill, you want to start from the top down and the sides in. You want to push the air over the top and sides as much as possible for the best aerodynamics.
The Following User Says Thank You to ChazInMT For This Useful Post:
aerohead (09-26-2014)
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 10:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 01:31 AM
Permanent Grill Block Raysp30 Aerodynamics 7 10-04-2011 01:30 AM
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 06:16 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 04:09 PM
