Old 06-06-2015, 06:39 PM   #1 (permalink)
EcoModding Jack
nimblemotors's Avatar
Wheel Spinners / Floaters for better aero
I've been working on the wheel covers for the Indy One,
and wanted to bring up an idea I have had for covering the wheel wells,
by using essentially 'wheel spinners'. These are wheel covers that have bearings and so spin asynchronous to the wheel.
When the don't spin at all, it looks like the car is 'floating', as the wheels appear to not be spinning at all. So while that is a neat trick, why not use it for a wheel well covering instead?
Old 06-06-2015, 07:29 PM   #2 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I think we spoke about that before on E.M.
Good idea - go for it !
It seems to me that it would be cheaper to simply do a good gap fill around the front wheel and install some smooth hub caps.
I would think the air would skip right over the wheel with minimal turbulence.
Darin ( MetroMPG ) found that a smooth wheel cover and gap fillers worked well enough on his Firefly ( Metro ) to not even consider front wheel skirts/pants/covers/ etc.
I must admit though that I would love to see what you come up with.
Old 06-06-2015, 07:51 PM   #3 (permalink)
Valerie - '03 Honda Civic DX
90 day: 55.79 mpg (US)
A-B-A it and see if there is an improvement!
Old 06-06-2015, 08:35 PM   #4 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I've seen plastic wheel covers on the taxis here that work in a similar way, except they're weighted at the bottom to remain stationary. They carry advertising on them.
Old 06-07-2015, 02:07 PM   #5 (permalink)
To what point? If the 'hubcap' is symmetrical the cross-section it presents to the air is constant. The only thing that would change is skin friction and while that wouldn't change at 3 and 9 o'clock, the friction generated at 12 and 6 o;clock would trade off.
As soon as you go to an asymmmetric profile, best practice would be to wrap it around the back of the tire into a cycle fender. Would this be on an open [front] wheel, or an enclosed [rear] wheelwell?
Old 06-07-2015, 03:04 PM   #6 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
If you're doing a tadpole, why not just set the front wheels to be covered by the widest point of the body?
Old 06-07-2015, 03:49 PM   #7 (permalink)
EcoModding Jack
Symmetrical hubcaps are symmetrical because they aren't spinners.
I would think there is potential gain from not having the hubcaps spin with the tires even if symmetrical. Whether worth the trouble/expense maybe not.
It does open up some possibilities that might not have been thought of,
if nothing else might have some interesting asthetics.
The wheels are covered by the body in the Indy One.
It is the gap that I'm thinking about. There can be more than one wheel tire size, so the gap can't be made real tight.
Old 06-07-2015, 05:04 PM   #8 (permalink)
Team Saturn
When you say the wheels are covered by the body, do you mean enclosed - can only see the bottom of the tires/wheels, or like a typical production car's body covers them - not an open wheel vehicle?
Old 06-07-2015, 07:35 PM   #9 (permalink)
Your brave new future was depicted in Bladerunner.
And presaged by Preston Tucker's Carioca sports car proposal.
http://en.wikipedia.org/wiki/Preston_Tucker#Speculation_and_controversy_surroun ding_the_Tucker_Corporation
Edit: Here's an Alex Tremulus design for Tucker I hadn't seen before:
https://www.pinterest.com/pin/315322411380308968/
Cd (06-07-2015)
Old 06-08-2015, 05:26 PM   #10 (permalink)
asymmetrical
You might do a mock-up and attach it to one of the wheels and then run it through the entire range of wheel flop to see if there's interference anywhere.
If you like what you see,then it's a sure thing.
Basjoos ran the equation backwards for AEROCIVIC,with skirts which respected the front wheels full range of motion.
