Grill block mounting help
Im looking to make a set of brill Blocks for my VW Passat and im making them out of clear Perspex so they are as clean and stealthy as i can get it as i want to have a factory fitted look but my problem is how can i mount them with out having bolts or cable ties showing?
im looking to do all 3 Lower grills with a vent in the center grill. Also a Half block on the Large center Grill with the VW Logo. I want it to look a clean as possible. Thanks Carl |
1 Attachment(s)
Maybe you could cut grill block with some additional mounting points, heat them up and bend to the inside, then use zip ties or screws to mount it?
http://ecomodder.com/forum/attachmen...1&d=1351165660 |
I did think about that but there isnt enought clearance between the bumper and the grill.
Can you take a pic of the actual front of your car? That will be easier to see what we're talking about.
Yes i will get one up in a bit.
http://i136.photobucket.com/albums/q...8l/passat7.jpg
The grills are a tight fit in the resess of the bumper the upper grill should not be a problem its just the lowwer grills. |
Why you don't want to use those holes in a "black" area? The actual grill...
The two side grills are only half open and dont fancy having visable cuts in them.
1 Attachment(s)
Maybe some thin pieces of inox, screwed to the Prespex and fitted into the tight space between grill and bumper cover?
http://ecomodder.com/forum/attachmen...1&d=1351173246 |
You could put the grille block on the inside, for that stealthy look.
