Ok, not exactly sure where to start, I know lots of stuff about the Shuttle Transportation System (STS)...
1) That tail has been around since before the STS started flying (they had a prototype Orbiter model (the Enterprise) that they used for aero testing that they piggy-backed on a 747, perhaps this very plane), so most likely NASA didn't take the idea from a fellow EcoModder...
Here is a picture from (I think the 70's or early 80's) that is about the same as above. It shows some of the testing they had to do. In this test they would take the Orbiter up and release it so it could be landed. At the time I don't think they had a means of escaping if anything went wrong, so I guess you just hoped things worked.
2) The STS uses two types of fuel. The Orbiter uses a Liquid Oxygen / Liquid Hydrogen (LOX/LH2) mix, that burns at a more or less constant rate for about 1000 seconds. It also has Reusable Solid Rocket Boosters (RSRBs) that burn at a more or less constant rate for about 125 seconds. The STS uses a lot of fuel at lift off, but it uses that much fuel for a long time... If you really want, I can see about finding a graph that will show the fuel use over time...
3) The Pictures above don't show how the Shuttle takes off. It is just getting a ride back to Florida since it had to land in California due to weather issues. The Orbiter takes off on the back of the External Tank (ET) with two large RSRBs. The RSRB's drop off about 125 seconds into the total burn, and the Orbiter powers it's self and the ET into orbit, where it drops the ET, and the Orbiter continues on it's way to the International Space Station (ISS).
Here is a picture of the STS taking off. You can see the Orbiter piggy-backing on the red/orange ET with the white RSRBs on the side.
