07-12-2010, 10:34 PM
Is Regenerative Braking Real? Does it work as we thought?
Is Jack Rickard correct about there being zero gain -- or even a loss, when regenerative braking is used in an EV?
If you have an EV, can you try to duplicate his results? He is even seeing a 7% *loss* when regenerative braking is used.Like him, I am very surprised at these results -- they make no sense.
EVTV.ME: More Regenerative Braking Results. It gets worse...
He is already working with Illah Nourbakhsh (at Carnegie Mellon), so hopefully we can sort this out?
Regenerative braking in the Aptera - is it merely dogma? - ApteraForum.com - Unofficial Aptera Car Forum
07-12-2010, 10:41 PM
needs more cowbell
FYI, when looking at using a freewheel on my bicycle vs a fixed gear, the figure I saw was that the regen would return %18 of what you put into it, and the constant friction reduced the bikes ability to coast well beyond what you would get back from %18 of your braking energy. So most bike sized EVs opt for free-wheel.
Not an EV only problem though, hybrids have the same concern.
07-12-2010, 10:51 PM
The three modes that Jack Rickard tested (on the first car) included one where it could coast freely, and only had regen on the brake pedal. This still returned no better results than when *no* regen was used...
Something does not compute. And Jack is puzzled, too.
07-12-2010, 10:57 PM
Left Lane Ecodriver
Regen works on my (PH)EV. Evidently, when he replaced his DC motor and controller with AC, he selected less efficient components.
Also, he was talking about being constantly in regen or assist. If he doesn't have a neutral position in his transmission, then he needs a "zero amps glide" setting on his throttle. DWB and long coasts work better than regen.
The Following 3 Users Say Thank You to RobertSmalls For This Useful Post:
07-13-2010, 05:11 AM
Didn't check the links but I'll say that a properly driven vehicle doesn't usually need much braking at all on the non-urban flatlands so regen maybe wouldn't be worth any cost/equipment penalty, but I've spent enough time in hilly areas to really, really wish I had regen there!
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
07-13-2010, 07:20 AM
What is he using a the regen element, the motor rotor? or and independent charge item like edy brakes?
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
07-13-2010, 08:20 AM
Yeah I'm not sure what systems hes using either, but if the regen setup is working correctly its going to recapture energy, period. Sounds like his system isn't properly designed, or his testing is flawed.
07-13-2010, 09:22 AM
PaulH
hello!
07-13-2010, 09:32 AM
#9 (permalink)
I know regen works on my Prius. But it's set to about 10% of max with the the throttle off (to simulate engine braking on a conventional car). I usually apply just enough throttle to eliminate the regen when I want to coast - the Prius has a display that tells the driver when the regen is on and off so it's easy to modulate. Then when I approach a light or stop sign, I let off the throttle and let the regen resume and apply just enough brake (trying to stay within the regen zone so as not to engage the mechanical brakes) to get a smooth stop. I know the regen is working because I can see the battery charge level rise.
Possible reasons why the tester didn't see a benefit from regen:
A) Different conditions between tests.
B) Didn't do the math correctly.
C) Regen level set too high so that he was "hunting" between regen and applying power to maintain speed, wasting energy (due to system losses) along the way.
07-13-2010, 10:10 AM
#10 (permalink)
Hypermiler
I vote for C. Neutral coasting would be better in most cases.
