half tonneau length
Has anyone tested various half tonneau lengths? Maybe also on various bed lengths? Or does half of any bed length seem to be perfect?
Find out where the template would touch the bed rails- that'd be a good starting place for the leading edge of a half tonneau. If you need it farther back to give more bed access, try experimenting, but I'd start with the template coming down from the cab roof.
I think I saw a template on my truck and it may have not come down inside the bed. I've got a ranger with a 6' bed
I don't think the Template will do it.
What your looking for is a rolling cylinder of air in the bed. It may have more to do with the distance from the bed floor to the top of the cab. |
I figured the tonneau would make the bed floor moot.
For a full tonneau, sure. The question is a half-tonneau.
Maybe a curved mid-wall? |
various lengths
*Any coverage,of any length provides a drag reduction. *The drag minimum occurs at 50% (half) coverage (back half). *They tested on a C-10 1/2-ton. *The half tonneau gave a 8% drag reduction. *The full-tonneau gave a 5.6% reduction. *The 1/2-tonneau with forward bulkhead had 12.8% higher drag. *And the 1/2-tonneau cut rear lift by 30%. -------------------------------------------------------------------------- In 1988,Texas Tech investigated the tonneau and also advocated the 1/2-tonneau. If you need numbers for various bed lengths you're on your own. |
Thanks for the info. Google kept giving me links to half tonneau covers to cover the rear seats of old convertibles.
That's why we're here. We keep chanting the Old Wisdom in the hope of keeping it alive.
It seems like it could be workable — butterfly opening hatches on the half tonneau and the 'mud room' area ahead of that could be waterproof so you could use it for a bath tub. |
