Has anyone lightened factory steel wheels?
I have many spare stock 14" steel wheels for my 95 accord lx. I did some searching looking for examples of drilling, chemical milling, acid dipping or any other ideas but came up empty handed.
I suppose it is feasible. I would question the reasoning. I have a set of 14 inch steel rims for an application and found that they were lighter in most cases than just about all the aluminum factory and aftermarket rims available.
If you want to go forward and do some lightening, safety becomes an issue. Wheel design isn't for the faint of heart and ignorant. It is the first contact your car has with the road and is one of the most highly loaded parts of your car from a dynamic range of rest to pot hole hits at speed. |
I weighed one last night, 18 lbs. That seems heavy to me for a 14x5.
I engineer light weight high speed machines for a living. I will not modify wheels or most suspension parts.
There are too many ways that something can go wrong, the consequences are too severe, and the weight reduction is minimal. |
FWIW, 25-50% weight reduction thought possible (11 years ago) for OEM wheels with different design and manufacturing techniques: Cambridge Journals Online - Revue de Métallurgie - Abstract - Steel solutions for mass savings in the wheel industry
My interpretation on that line is.................will work until you hit your first pothole. Local service conditions in SE Michigan would mean reinforcing your wheels, not thinning them out. |
Thanks for all the responses! |
I just ditched a stock set of Honda steelies because 2 were bent severely. I didn't bend them to my knowledge however I watched them on the balance machine and they were severe. The car would vibrate bad at speed. Depends on your budget but Craigslist has many 14" aluminum rims coming through. I got a great set from an 03 Honda civic hybrid for 275 shipped however there are definitely more affordable options out there. I'm not sure if your car is 4x100 or 113 but you will be able to find something if you look long enough.
It would probably be cheaper, easier, better, safer, etc... to just go buy some alloy rims.
