Old 07-05-2013, 03:04 AM   #1 (permalink)
Exceptional Member
YukonCornelius's Avatar
Crapolier - '98 Chevrolet Cavalier base
90 day: 34.81 mpg (US)
05 CTS-V - '05 cadillac cts-v
90 day: 33.01 mpg (US)
95 Accord - '95 Honda Accord
90 day: 38.06 mpg (US)
11 CTS-V - '11 Cadillac CTS-V
Has anyone lightened factory steel wheels?
I have many spare stock 14" steel wheels for my 95 accord lx. I did some searching looking for examples of drilling, chemical milling, acid dipping or any other ideas but came up empty handed.
Don't know why it says 00, it's a 95
374,000 miles and tired.
Old 07-05-2013, 10:25 AM   #2 (permalink)
I suppose it is feasible. I would question the reasoning. I have a set of 14 inch steel rims for an application and found that they were lighter in most cases than just about all the aluminum factory and aftermarket rims available.
If you want to go forward and do some lightening, safety becomes an issue. Wheel design isn't for the faint of heart and ignorant. It is the first contact your car has with the road and is one of the most highly loaded parts of your car from a dynamic range of rest to pot hole hits at speed.
The Following 2 Users Say Thank You to RustyLugNut For This Useful Post:
mcrews (07-08-2013), sully06 (07-05-2013)
Old 07-06-2013, 02:43 PM   #3 (permalink)
Exceptional Member
I weighed one last night, 18 lbs. That seems heavy to me for a 14x5.
Old 07-06-2013, 03:22 PM   #4 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 41.21 mpg (US)
I engineer light weight high speed machines for a living. I will not modify wheels or most suspension parts.
There are too many ways that something can go wrong, the consequences are too severe, and the weight reduction is minimal.
The Following User Says Thank You to JRMichler For This Useful Post:
mcrews (07-08-2013)
Old 07-06-2013, 06:35 PM   #5 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Those are heavy rims. You can find 14" rims 8-12 pounds at junk yards without to much trouble.
Old 07-06-2013, 07:53 PM   #6 (permalink)
FWIW, 25-50% weight reduction thought possible (11 years ago) for OEM wheels with different design and manufacturing techniques: Cambridge Journals Online - Revue de Métallurgie - Abstract - Steel solutions for mass savings in the wheel industry
Old 07-07-2013, 08:42 AM   #7 (permalink)
Research Article
H. Luccioni
Abstract
Two different approaches are available to reduce the mass of automotive steel wheels. The traditional approach is based on the use of high resistance steels that allows a thickness reduction of the rim and disc. A mass reduction up to 25 % can thus be obtained. A different approach allows a larger mass reduction with a more drastic change in the wheel production technology. One possibility is to use laser welded blanks to feed the existing manufacturing lines. Another possibility is to implement a combined spinning and rolling of the rim. These new steel solutions allow a mass reduction up to 50 %. Indeed they allow adjusting precisely the steel thickness and properties to the local service conditions. Finite elements calculations have been carried out to assess the static and dynamic behaviour of the new wheels.
RE: Indeed they allow adjusting precisely the steel thickness and properties to the local service conditions.
My interpretation on that line is.................will work until you hit your first pothole.
Local service conditions in SE Michigan would mean reinforcing your wheels, not thinning them out.
Old 07-07-2013, 03:24 PM   #8 (permalink)
Exceptional Member
I'll check out the local yard for some dinky 14's. These old Honda wheels are certainly overbuilt. I have not bent one in 9 years, even after some serious abuse that goes beyond a nasty potholes.
Thanks for all the responses!
Old 07-07-2013, 08:34 PM   #9 (permalink)
The 'Vic - '96 Honda Civic DX
90 day: 39.3 mpg (US)
I just ditched a stock set of Honda steelies because 2 were bent severely. I didn't bend them to my knowledge however I watched them on the balance machine and they were severe. The car would vibrate bad at speed. Depends on your budget but Craigslist has many 14" aluminum rims coming through. I got a great set from an 03 Honda civic hybrid for 275 shipped however there are definitely more affordable options out there. I'm not sure if your car is 4x100 or 113 but you will be able to find something if you look long enough.
Civic Build Thread
Your grammar is appreciated.
3.788 Civic CX final drive, air dam, 1st gen HCH 14" wheels and Michelin Defender 175/65R14 LRR tires
Old 07-08-2013, 01:21 PM   #10 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
It would probably be cheaper, easier, better, safer, etc... to just go buy some alloy rims.
