Old 02-05-2019, 12:51 PM   #11 (permalink)
Yeah - solar roads sounds good - UNTIL you think about it.
Old 02-05-2019, 04:09 PM   #12 (permalink)
Solar panels belong on your roof not under your tires
TexasCotton (02-05-2019)
Old 02-05-2019, 07:58 PM   #13 (permalink)
TexasThunder Avg MPG 54 - '08 Toyota Prius Base
solar money way
I have seen the basic premise on SR
downsides
costly
low energy generation
good way to get crowd funded a literally use other peoples money OPM
survey says SR are limited and not worth
Old 02-06-2019, 12:02 AM   #14 (permalink)
Likewise, you don't want the rubber worn off of everyone's tires smeared all over your solar panels.
Xist (02-06-2019)
Old 02-06-2019, 11:52 AM   #15 (permalink)
Generally speaking, trying to achieve 2 vastly
different goals in 1 product results in both goals being suboptimally met.
So, the CR-Z?
Old 02-06-2019, 11:53 AM   #16 (permalink)
Snow plowing, sanding and salting your solar panels - would be awful!
Xist (02-06-2019)
Old 02-12-2019, 06:59 PM   #17 (permalink)
I can't help but remember I-80 over Donner Pass (California/Sierra Nevada). When I last drove that stretch (a few years ago now), traffic had worn ruts into the concrete deep enough that I worried about high-centering the Insight on them.
Old 02-12-2019, 07:10 PM   #18 (permalink)
Did you stop at the restroom at the summit?
I did a few years ago and it was the most palatial restroom Ive ever seen. The lobby is larger than a house, and the men's wing (I presume women's as well) had floor to ceiling glass block windows so it's flooded with light.
Old 02-13-2019, 02:45 PM   #19 (permalink)
Did you stop at the restroom at the summit?.
Have often stopped there. Used to drive that way fairly frequently, as it was the best way to get from my old place to the north Bay Area. Nowadays California 88 over Carson Pass is shorter, and a much nicer drive even though the rest area at the pass is a bit on the primitive side. But fortunately I can now use electrons instead of driving :-)
The Following User Says Thank You to jamesqf For This Useful Post:
freebeard (02-13-2019)
Old 03-08-2020, 07:52 PM   #20 (permalink)
Why solar roads are dumb.
https://youtu.be/O0yn-xBjb9c
scam
