Is having a hole in my head better than having a screw loose?
I lost bone around the implant and my old dentist is removing it. She said she will give me a quote for a bridge, but I don't know how that would work out since the back tooth has an implant (in my trunk).
Remembering is hard! I thought it would be weird if someone from the dealership opened a box with broken teeth, but it would have been nice if this dentist could recement them. How do I Heli-coil my own jaw?! |
"How do I Heli-coil my own jaw?!"
..you start with a good slug of whisky!! Years ago, I had a large amount of bone removed; some surgically, some by the absess growing there. It took a LONG time to completely heal. Good luck! |
So you're saying there's a chance!
I do not like the idea of missing bone! |
You're only young?
Good diet, no cigarettes, easy on the booze...you can recover from most things. |
I try to take care of my cars, too, and that is a losing battle, but they don't heal.
Fewer teeth means fewer dental problems.
My Metro has taken to not sweeping the wipers as far and then slapping them on the hood. |
loosen whatever device holds the arms on, remove arm , reposition, reinstall locking device. Generally they should be about an inch from the bottom of the window.
Thanks. I suspect some cable mechanism because they are in synch, but that's within the scoop of my capability.
I'm still starting it with a screwdriver. The replacement steering column just sits there and doesn't install itself. I think Xist is being a bad influence on me. :( |
You "heli-coil" your jaw with a bone graph. You keep from losing another implant with excellent oral hygiene that includes daily flossing. Bone loss is caused by bacteria between the gum and tooth / implant generally from excess plague buildup. (And this reminds me that I need to step up my flossing - as my wife and dentist continue to remind me on a regular basis) |
I've wanted dentures from the moment I knew they existed... also wanted a powered wheelchair from the moment I knew they existed.
https://media.tenor.com/r4NPvBtf6gsA...sons-homer.gif |
