Old 09-15-2012, 05:39 AM   #1 (permalink)
Heated vs non heated o2 sensor
I read the 02 sensor does not work till it is 300degrees. I cheaped out and replaced the heated 02with an unheated o2 on my tail pipe. Did this hurt my mpg? 94volvo940 wagen. sC
Old 09-15-2012, 06:07 AM   #2 (permalink)
I would think it would delay initial function. That's about it unless you are having other problems since installation.
regards
Mech
SmellyCat (09-15-2012)
Old 09-15-2012, 06:18 AM   #3 (permalink)
Would the car run rich or lean while the o2 sensor was heating up. The engine seems to run fine. Sc
Old 09-15-2012, 09:19 AM   #4 (permalink)
GTR
Red VX - '93 Honda Civic VX
Teal VX - '94 Honda Civic VX
Godzilla - '09 Nissan GTR Premium
Probably just runs in open loop mode, which is likely richer than closed loop. It's running a pre calibrated ratio of air/fuel, rather than using the o2 sensor to adjust air/fuel on the fly to achieve the best ratio as you drive.
