05-24-2012, 06:33 AM
master modder
heater core bypass?
has anyone ever done a heater core bypass??? did you see better mpg from it?
i think it would help without
05-24-2012, 07:48 AM
If you have a really short commute it may be worth while to look into. Other than that I don't see it having much effect.
05-24-2012, 08:10 AM
master modder
oh well your probably right
-its hard to have a fun life if you don't have fun in life-
05-24-2012, 08:24 AM
Any idea how much coolant the heater core holds? I think my entire coolant system for my ~1.5L engines hold about 1 gallon. If we get a few numbers on things we can calculate what % of thermal mass the coolant in the core consists of versus the coolant in the engine and the thermal mass of the engine.
05-24-2012, 08:36 AM
master modder
6 liters well im thinking about how the coolant is circulating all the time
05-24-2012, 08:40 AM
Yeah I understand. By bypassing the heater core you would lessen the initial amount of thermal mass you need to heat to get the engine up to temperature which means you get up to temperature faster. Its not a bad idea, we just have to determine if we're actually reducing that by any notable amount. My initial guess is probably not, but it can be calculated.
05-24-2012, 08:52 AM
My heater core has a valve on it that it only opened up when the heat is turned on.
The Following 2 Users Say Thank You to Ryland For This Useful Post:
05-24-2012, 04:05 PM
Wanting more for less
My cars do also.
I've read on performance sites that a heater bypass can cause hot spots in the engine due to changed coolant flow.
It's better to simply block the coolant lines to the heater if you want to remove it.
05-24-2012, 10:11 PM
#9 (permalink)
master modder
ya your right on  wait how can we calculate it?
05-24-2012, 10:13 PM
#10 (permalink)
master modder
cool! what kind of car you got? can i buy the value aftermarket? for say a 97 nissan pickup lol
