Old 11-28-2008, 04:48 AM   #1 (permalink)
You must be joking - '97 Subaru Impreza Sport
Heater fan
Hi all,
I have an Impreza classic 2.0. I tend to do subtle mods for general improvements but it's not the most economical car ever, slightly underpowered and 4WD.
I read something on these forums that got me thinking. Reducing electrical load will reduce alternator load.
In the Impreza there is very little air flow without having the heater fan on. It has 4 speeds, position 0 is off. The speed is controlled by a resistor pack and it gets very very hot. It's excess heat is sinked into the air flow from the fan. This probably explains why the output is always warmer than outside temp. On full speed, the fan gets full 12V and the pack does not get hot.
I have wondered if the resistor pack could be replaced by something more sophisticated that produces less heat and puts less load on the alternator when used on the lower speed settings.
Better Off OUT of the EU
Old 11-28-2008, 11:02 AM   #2 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.64 mpg (US)
Replace it with a fan motor wound for multiple speeds. That's just about the only way to go about it cheaply.
Another alternative, although it would probably be cost prohibitive, would be adding voltage step downs to the lower speeds.
Electric vs. belt driven cooling fan Gregte EcoModding Central 63 06-18-2013 06:42 AM
Geo Metro Block Heater How-to bbjsw10 DIY / How-to 75 12-31-2009 12:34 AM
S10 radiator fan changes? bennelson EcoModding Central 29 12-29-2008 07:54 PM
Honda civic fan speed control possible mod Vince-HX EcoModding Central 0 08-17-2008 10:48 PM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 10:31 PM
