Old 10-28-2010, 06:37 AM   #1 (permalink)
Aveo - '08 Chevolet Aveo LS
Hello
Hi, I'm Scott
I recently acquired a 2008 Chevy Aveo sedan automatic with 34k miles on it, and I'm interested in saving some fuel. As a broke college student, every little bit helps.
The only thing I've done to it, at all, is a new STP air filter (stock size), and new NGK iridium IX spark plugs. (60k mile duration, 0.6mm tip)
I was wondering what cheap/free mods I can do to save fuel.
I drive pretty conservatively, and I already drop the car in neutral while coasting...
What is my best bet on what to do?
Old 10-28-2010, 08:59 AM   #2 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Welcome to EM
One that's easy to do an rather effective is blocking the grille - partially or fully, depending on the weather and the coolant temperatures you get.
Read up and start putting these tips into practice :
65+ Vehicle modifications for better fuel economy - EcoModder.com
100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com
Some are quite involved, others bordering on the obsessive, but many are actually really easy to do.
Old 10-28-2010, 03:45 PM   #3 (permalink)
blocking the grill...
what would you recommend to do that with?
Old 10-28-2010, 07:27 PM   #4 (permalink)
euromodder's Avatar
I've used tape for a trial-installation.
Others have used draught-blocking foam, fiberglass, sheet metal, or corrugated plastic (coroplast, the stuff real-estate signs are made of), even plastic film.
Done on the inside like the car manufacturers do, it's an invisible mod.
For some cars, grille covers are commercially available - mainly for winter use.
Old 10-28-2010, 07:34 PM   #5 (permalink)
If I were to only block one, top or bottom?
Old 10-28-2010, 07:56 PM   #6 (permalink)
euromodder's Avatar
Top is usually most efficient.
On the new (Euro) model Aveo, half the huge lower grille is blocked right from the factory !
Keep an eye on the engine coolant temperature when doing these mods - especially next summer.
