Old 11-04-2012, 05:22 AM   #11 (permalink)
The PRC.
Welcome - Apologies if I missed it, have you upped the tyre pressures ? Also cruise isn't the best although dropping speed is
Old 11-04-2012, 08:49 AM   #12 (permalink)
Arragonis - ive had them slightly increased for years. I do not go too much as when pushed hard, tire pressure increases to undesireable levels that affect the handling...bit different in winter with colder temperatures i increase them a bit more as 1) i dont have my moments of flying about as much and 2) if i do have some slight moments, the tires do not warm up as easily. My winter tires however are always set highish as i never push the car with them on. I wont go into slower speed bit again as it seems only a few grasp it. As for cruise control...all depends on how you use it amigo.
