Hello from Huntsville, AL!
Hey everyone! Long time lurker, network engineer, and "Rocket City" resident here. Sold my beloved 2004 Ram 1500 Quad Cab 4x4 and purchased my sister in law's 2004 Honda Civic Coupe LX Auto-trans (55,000 miles on it); because I do nothing but commute with my vehicle and my wife and I bought an SUV to accommodate the kids and tow the boat. The car was in decent shape, but not anything spectacular; needed a lot of mechanical love, some minor exterior love, and a deep interior clean. I'm looking to try to eke 40mpg (hopefully more!) out of this car and so far with some hypermiling techniques (neutral coasting as much as possible, some FAS, DWL, etc) I've been able to squeeze almost 34mpg out of this car (which is EPA highway) around town. My work commute is 15 miles of a handful of stoplights and some swoopy hills and averages around 40-60mph (I refuse to travel over 60 when I'm concerned with FE).
I'm concerned that something else could be wrong with the car and that's why I'm finding myself only able to currently squeeze out EPA HWY mileage while being so diligent with maintenance and FE techniques. I've changed coolant, thermostat, rad cap. Purchased an SGII. Checked, cleaned, and regapped spark plugs. Air filter replaced. All brake components from the lines to the rotors/drums replaced. Transmission fluid has been drained and filled 3 times now to bring the fluid up to snuff (Currently using Mobil1 Synthetic ATF, will change to Amsoil Fuel-Efficient ATF). Power steering fluid drained and filled 3 times with fresh synthetic fluid (there was notable PS whine when I bought the car). Tires aired up to sidewall max plus 5psi. I haven't changed the oil yet because my sister in law just had the oil changed with a synth-blend Valvoline before I bought the car and I just don't have it in me to change perfectly good oil atm. Once it goes to 60,000 miles (~5000mi from now) I'll change out to Mobil1 5w-20. It's good to meet everyone! EDIT: Where do I get one of those SWEET ecomodder signature images that displays your vehicle, MPG, percentage over EPA estimate, etc?! |
Welcome to the site. I have little doubt you'll be able to get the Civic up to 40 mpg. Good luck with it!
Here is how to setup your signature: http://ecomodder.com/forum/showthrea...ure-20941.html |
You should have no problem beating 40 MPG in your Civic! Without hypermiling I was getting ~35 mpg. With hypermiling I was getting 39-41. And now with ecomods my current tank finished off at 44 mpg. And most of my trips are short 5-10 mile trips. Mine is an auto as well.
Got it. Thanks Daox!!!:thumbup:
I noticed quite the improvement in coasting ability from the wheel covers, grille blocking, and fog light covers (you can view my Ecomodder build thread here). I haven't installed an air dam yet but will hopefully do that this weekend. This generation Civic (mine, at least) seems to get the best FE at 36 mph, right when it shifts into overdrive. Best range seems to be 36-43 mph. |
Anywho, I'm going to get my hands on some packing tape to test out some grille blockage and remove the mirrors this weekend. I'll make a build thread and hopefully report back! |
Before modding I averaged 39 MPG with cruise control set at 55 mph. I haven't tested that since modding since I've rarely gone above 43 mph. Packaging tape can ruin your paint, just like duct tape. I used blue painters tape and then covered it with colored duct tape. Painters tape is easy to remove (people with $10,000 paint jobs on their cars use it to protect their cars' paint jobs when taking their cars to car meets) and it doesn't damage your car's paint. And of course duct tape over it covers the ugly blue color. ;) |
Ah, good to know. I keep a pretty regular coat of Meguiar's Ultimate wax on all my vehicles so I'd rather not damage the paint. I'll be sure to do the primary adhesion with painter's tape first as you've suggested. Thanks! |
Copyright ©2000 - 2021, vBulletin Solutions Inc.
