Old 10-30-2013, 10:27 PM   #11 (permalink)
Originally Posted by Obormot View Post
more than 5 years i working with ethanol based motor fuels.
i converting cars to E85 and to pure ethanol here, in Ukraine, also producing devices for conversion for export, for example, E85 conversion kits for injection cars, and "small additional gas tank" cold start kits for using pure ethanol instead E85 (like in Brazil).
Nowadays even some Brazilian-made flexfuel cars are getting rid of the auxiliary cold-start tank, most notably the ones fitted with Peugeot/Citroën VTi 120 FlexStart (Citroën C3 hatchback and C3 Picasso, Peugeot 208 and 308) and the Honda Civic FlexOne. These are fitted with heating coils integrated to the injector tips, a system developed by Bosch. I live in Brazil and I had contact with ethanol-powered cars since I was a kid...
Old 10-31-2013, 02:45 AM   #12 (permalink)
Obormot's Avatar
wow, heated tip injectors already in production? can you give a link ?
i seen only one sample from Delphi some years ago, and i do not know, if it was installed to real cars.
Delphi Multec 3.5 Heated Tip Port Fuel Injector
http://delphi.com/pdf/techpapers/2009-01-0615.pdf
http://delphi.com/pdf/techpapers/2012-01-0418.pdf
i know that Bosh makes heated fuel rail with usual injectors.
i was trying to made heating for fuelrail, it was effective for starting on pure ethanol up to about -5C, for colder temperatures - still bad.
also heating of all fuelrail takes too much power from accumulator, it is critical at -20C for example.
and many cars has fuelrails with return line, so heating has no sense...
additional gasoline tank was very simple and cheap solution and works very good on any cold
anyway, pure ethanol not become popular here (now i working mostly for export) and all this devices not needed now, but maybe later...
Old 10-31-2013, 10:22 PM   #13 (permalink)
Flex Start Bosch ∙ Ligou ∙ Pegou ∙
You might wanna check it with Google Translate
Old 11-03-2013, 04:39 AM   #14 (permalink)
Obormot's Avatar
o, i laready seen it, it is not heated injectors, it is heated fuel rail.
i already try it, not very good.
but maybe enough for hot Brazil...
Old 11-07-2013, 04:35 PM   #15 (permalink)
There are cold weathers during the winter, but not usually so extreme as in the North hemisphere.
