Old 12-03-2013, 03:22 PM   #11 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by damarble View Post
I did a full grill block and deleted the sun visor.
The role of the sun visor is still highly uncertain as no-one has dared to test it before
But I got a noticeable reduction in instant-fuel consumption all across the board on my previous car.
Just about every car manufacturer is using them these days to block the often massive marketing-grille that the engineering dpt. doesn't need.
Old 12-03-2013, 04:42 PM   #12 (permalink)
I really think gearing is holding me back. I was able to pull every mountain pass in overdrive with barely any throttle increase. I'm considering going with a slightly taller tire when these wear out, maybe a 33 instead of these 31s. Yes it will make aeros worse but it should lower RPMs a bit which is what a diesel needs.
