Old 03-02-2011, 07:55 AM   #1 (permalink)
Smokingwheels - '84 Nissan Bluebird wagon LX
90 day: 35.99 mpg (US)
Red Z - '79 Nissan 280 ZX
Blue Ford - '95 Ford Falcon GLI
90 day: 18.18 mpg (US)
Send a message via MSN to Smokingwheels Send a message via Yahoo to Smokingwheels
My best city test yet for my Wagon
* 1984 4 cylinder 2L Wagon with carby and special porting*
* ambient temperature, 29.9 Deg C
* humidity, 13%
* Windspeed/direction, ENE/16km/h
* fuel grade/quality, ULP
* payload, Full tank + 85 Kg + notebook pc witch is my engine timing controller
* elevation, about 306 m AMSL
* road grade, fairly flat
* speed, 40-50,60, 60, 60 Km/h eg running laps around the block 12 times with stop signs on each corner.
* other traffic lots on one side of the run around the block 12 Times eg crosswalk
* driving style, no hooning here, About 200mm of Hg when accelerating
* Compression ratio, approx 10.5
* Distance on run 67.604 km
* idle time about 15%
** Fuel Consumption **
Best test results 6.271 L/100, 37.51 mpg (us), 45.05 mpg (imp)
normal running 11.2 L/100, 21 mpg (us), 25.22 mpg (imp)
My Tacho Graph
And for some more stats see http://203.161.71.130/forum/topic.asp?TOPIC_ID=9
Last edited by Smokingwheels; 03-20-2011 at 03:56 AM.. Reason: Wrong Elevation, add tacho graph
