Old 06-05-2008, 03:55 PM   #1 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Outside spare tire drag on SUV?
With all the turmoil that going on in back of this brick, does it really matter that a spare tire is hanging out there?
How much could it help the cd if the spare was carried inside the car?
(I'm sure it would help if I left it at home)!
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 06-05-2008, 05:40 PM   #2 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
leaving it off will save weight so that might help, but if you're going to carry it that would be the best spot i think (unless you could put it on the front where it might serve as a grillblock and make the nose a little more pointy...) you could even argue that in a very crude way it extends the car and creates some sort of boattail.
in the real world i don't think it will result in any measurable gains. kammback lip spoilers at the roofline and the sides might give you better FE results and at the same time might cause less practical problems.
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 06-05-2008, 06:01 PM   #3 (permalink)
igo
igo's Avatar
Mini Box Truck - '05 Scion Xb
90 day: 32.87 mpg (US)
It FITs - '09 Honda Fit Sport
90 day: 36.2 mpg (US)
Impreza - '13 Subaru Impreza Sport
90 day: 30.92 mpg (US)
Just don't put it on the roof!
I really don't think there will be any change in mpg on "tire in the back vs. tire inside"
Old 06-05-2008, 07:55 PM   #4 (permalink)
Red
Red's Avatar
Never noticed a difference on mine
Old 06-05-2008, 08:43 PM   #5 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
It probably has no measurable aerodynamic effect back there. Unless of course you were to use it as a mounting point for a partial boat tail...
Old 06-05-2008, 11:13 PM   #6 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
You know that if you ever back into something, that spare will cause more damage to the vehicle than without it.
GeoMetroforum.com - got mpg?
Old 06-06-2008, 12:01 AM   #7 (permalink)
That's a good reason for not having on the back. I've seen a few folks that backed into lamp posts at malls and really racked up some damage.
The Japanese CRV carries their spare inside..
Cheers,
Rich
Old 06-06-2008, 11:15 AM   #8 (permalink)
Ecomod noob
zjrog's Avatar
ZJ - '95 Jeep Grand Cherokee Laredo Upcountry
90 day: 20.57 mpg (US)
Neon - '03 Dodge Neon SE
90 day: 33.46 mpg (US)
S'Crew - '02 Ford F150 Supercrew XLT
90 day: 16.4 mpg (US)
Ranger - '90 Ford Ranger
Last 3: 28.02 mpg (US)
Not the Jeep - '03 Dodge Neon SE
90 day: 34.11 mpg (US)
Carrying the spare on the outside of the CRV makes it look more "manly". A marketing ploy. (It must be a capable machine, see, the spare is outside!) Take that tongue in cheek since I drive a Jeep... With the spare INSIDE...
When it comes to Heroes, RENEGADES are mine!
Old 06-06-2008, 12:07 PM   #9 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
If you don't want to carry it inside the cabin, you could always carry it inside the engine bay like old subarus did.
Old 06-06-2008, 12:23 PM   #10 (permalink)
Leave the spare tire at home and get a AAA card and a can of fix a flat. How often do you get flat tires these days?
CdA list Daox Aerodynamics 206 10-25-2023 06:32 PM
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 276 03-14-2022 03:51 AM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
