Old 04-14-2011, 11:31 AM   #11 (permalink)
Silver Turtle - '02 Ford Focus Zx3
90 day: 38.83 mpg (US)
I think its around 50 amps.
OH gosh so if I get a 50AH battery that means I can only run the car for one hour? (alternatorless?)... wow that seems very low. How do people go alternatorless if they can only drive the car one hour?!
Old 04-14-2011, 11:36 AM   #12 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Actually, you should only discharge them to no more than 75 percent...so with a 100ah pack, drawing 50a constant, you'll only get 1.5h usage... less when you consider losses.
Something tells me that 50a isn't normal usage for your car, though.
Old 04-14-2011, 05:05 PM   #13 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
something you need to consider as far as current is how much the batteries can handle, yeah your battery might have 50 Ah capacity but what is the maximum discharge rate? if your homemade pack can only handle a constant 20A draw and you try to draw 30A for an extended amount of time you can fry the pack
Old 04-14-2011, 10:04 PM   #14 (permalink)
Well those A123's have a 70amp con and 100amp discharge capacity so I doubt ill ever even come close to it... I think.
Old 04-15-2011, 11:31 AM   #15 (permalink)
you have to consider how much current your starter draws on a "cold" start, obviously it won't be as bad for you as it would be for me up here in Northern Illinois
Old 04-15-2011, 11:38 AM   #16 (permalink)
just some info for you
Ford Focus - hard starting
i don't know what engine your zx3 has, but this could be roughly the same
Old 04-19-2011, 02:53 PM   #17 (permalink)
Na thats the diesel model, but it could be the same? Plus I want to integrate auto start/stop and Im going to be replacing the starter anyway since I don't want it to die with so much constant use.
Old 04-19-2011, 02:55 PM   #18 (permalink)
I didn't even think about that lol. Good point!
For these batteries, couldn't i just wire them in series/parallel and directly to the +/- cables? Or would i need some sort of charge controller/voltage regulator or, well, anything else?
Old 04-19-2011, 03:14 PM   #19 (permalink)
i'm not sure what you would need exactly for charging the battery, if you plan to use a solar panel you can get a solar charge controller online for pretty cheap. as far as series/parallel you could do that to reduce the current draw on individual cells, but i'm not sure how you would calculate that. as far as that link i posted, i know that starter would draw more than you car (most likely) but if you build your pack to handle that much it would work just fine for your car (assuming the draw is less)
Copyright ©2000 - 2021, vBulletin Solutions Inc.
