Old 12-29-2008, 06:37 PM   #1 (permalink)
Tracy - '00 vauxhall corsa
help with multi meter readings on sensors
either my MAF sensor or my lambda sensor is broken -according to the vauxhall forum. symptoms are lack of power. i have found the data sheet for both sensors, they are both bosch. i attached meters to both sensors. they both seem to be within working parameters!
the lambda sensor jumps around between lean and rich, alrhough is mostly lean 99% of time <0.03v. the air flow sensor (MAF) is giving low valves acording to my calculations. at 60mph the reading should be 2.8v for 13miles/litre. now i'm getting 2.8v only under maximum load, (up hill, top speed).
i'm thinking that the MAF sensor has lost calibration and is falsely telling the ECU that there is low air flow when in reality there is plenty air flow. the ECU then reduces fuel flow to compensate and ends up causing a mixture too lean. does this explanation fit the observations?
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 11:38 PM
Water Meter for water savings!!! bennelson Saving@Home 3 12-11-2008 08:21 PM
Analog MPG meter. jim-frank Instrumentation 11 09-19-2008 12:38 PM
Restricted fuel system affect mpguino readings? wagonman76 OpenGauge / MPGuino FE computer 1 09-09-2008 02:34 PM
pressure sensors for testing grill blocks? pasadena_commut Aerodynamics 15 07-11-2008 12:34 AM
