Old 04-29-2012, 08:36 PM   #1 (permalink)
i2c LCD
Hello guys.. does anyone have the mpguino code to work with i2c lcd instead of serial? it would be a great help for me..
Cheers
Fábio Eliseu
Old 04-29-2012, 10:25 PM   #2 (permalink)
JellyBeanDriver's Avatar
The MPGuino code is for a parallel LCD display, not serial.
What display do you want to use? Does it have a daughterboard that is doing the I2C to parallel conversion?
1992 Geo Metro, 1.0L 5spd, 435,000 miles on the original engine and trans!
- knuckles/hubs/brakes/13" wheels from a 2000 Metro
- running 175 70R13
- averaging 51.7 MPG, 56.9MPG best tank.
- self built MPGuino
- http://www.dschmidt.com/MPGuinoJBD.html
Old 07-16-2013, 07:59 PM   #3 (permalink)
i try to use 16x2 lcd with l2cd of ebay what code modify for work with l2c instead of parallel?
this: IIC/I2C/TWI/SPI Serial Interface Board Module Port For Arduino 1602 LCD Display | eBay
thanks
Old 07-16-2013, 08:40 PM   #4 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
That's going to be a bit of work to write I2C code to replace the existing parallel LCD routines. You've got hardware coding to deal with, then you probably have protocol issues to address. Where is the specification sheet for this?
Old 07-17-2013, 06:42 AM   #5 (permalink)
LiquidCrystal_I2C1602V1
Description :
This is another great IIC/I2C/TWI/SPI Serial Interface. As the pin resources of Arduino controller is limited, your project may be not able to use normal LCD shield after connected with a certain quantity of sensors or SD card. However, with this I2C interface module, you will be able to realize data display via only 2 wires. If you already has I2C devices in your project, this LCD module actually cost no more resources at all. It is fantastic for Arduino based project.
Specification:
I2C Address: 0x27
Supply voltage: 5V
the backlight and contrast is adjusted by potentiometer
Come with 2 IIC interface, which can be connected by Dupont Line or IIC dedicated cable
Compatible for 1602 LCD
Old 07-20-2013, 02:54 AM   #6 (permalink)
Just use a parallel LCD. If you really want to use fewer pins, you can still convert your parallel LCD to serial, using a single inexpensive chip. It uses 5 pins total for the LCD, instead of 8, and the code library has already been posted on the web somewhere (very similar to the code in mpguino, so it's easy to update). More info at Arduino Playground - LCD3wires
The Following User Says Thank You to nickdigger For This Useful Post:
dewasha (07-20-2013)
Old 07-20-2013, 04:38 PM   #7 (permalink)
it is assumed that the chip is precisely for that to go from parallel to serial and therefore only uses 3 wires, the question is not the connection but the code to modify the obduino32k to work properly with a display connected serially with only 3-wire
Old 07-20-2013, 04:57 PM   #8 (permalink)
I converted my mpguino to 3-wire, using the 74hc164. I haven't built an obduino32k, but i'll look at the code & see what I can do for you (and everyone else).
edit1: Ugh. It looks like all the LCD code is in the Arduino library, not directly in the obduino source. This may take a while. I'm surprised the Arduino folks didn't add a 3-wire option to the library code. It should be a popular option for people wanting to use extra lines for an SD card, or other inputs.
edit2: Looks like someone else already wrote a replacement LiquidCrystal library for Arduino, including your i2c. You should find all you need right here: https://bitbucket.org/fmalpartida/ne...stal/wiki/Home
dewasha (07-21-2013)
