Old 06-30-2011, 01:30 AM   #1 (permalink)
High-MPG hot rod
Hey,
I like old cars. I want to build something for high-MPG and low emissions. I've gotta '61 Ford Ranchero project, and a '61 Mercury Comet that has a turbo 4-banger and runs on propane.
I'm trying to decide if I will build the Ranchero as is, or heavily modify it into a single-seater. I just got an early-70's Pinto "Kent" crossflow 1600 cc engine. I'm also interested in the Toyota 2TC (1600 cc) engine.
Thanks,
Kurt
Old 06-30-2011, 10:21 AM   #2 (permalink)
...beats walking...
...I had a '72 Pinto with that same Ford of Britian (FOB) 1600cc engine. Did you know that the old Formula Ford open-wheel race cars used that engine and pumped out well above 200 hp? That engine was also in the Capri and Cortina GT.
...from the Ford bulletin: Building an "Off Highway Inline 4-Cylinder Engine: 1600cc & 2000cc:
"The 1600 cc (97.6 cid) engine used in Pinto and Capri cars is based on a very successful 4-cylinder, in-line, overhead valve design that has been used on English Ford products for years...the most notable being the Cortina. It's an extremely durable design that has won thousands of rallies around the world. The most exotic version was double overhead cam design by Lotus that proved to be without peer in the rally world.
English Cortina models used 1.3, 1.5 and 1.6 litre engines, and you may find some of these in the USDA, via Canada. Cortina models designed for USA import used either 1.6 1V engines or 1.6 2V GT engines. Pinto and Capri cars use the "standard" 1.6 1V engine. The 1.6 2V GT version also forms the basis for a whole class of racing...known as "Formula Ford.""
...don't know if they're still available from Ford, but I got these many many years ago from Ford Marketing Corp/Parts Division, Livonia, MI:
Workshop Manual for the 1600 Cortina GT Formula Ford Engine; produced by FORMULA FORD REGISTER, P.O.Box 665, Dearborn, MI 48121.
Master Parts and Illustrations Catalog for Formula Ford, November 1969; produced by FORMULA FORD REGISTER, P.O.Box 665, Dearborn, MI 48121.
...with a few "tweeks" I was able to go from about 24 mpg to 36 mpg (header, electronic ignition, 3.18:1 axle (versus original 3.55:1), and front chin spoiler).
Old 06-30-2011, 12:18 PM   #3 (permalink)
Yes on the racecars, no on the manuals- I'll try to find some. It's good to hear you got pretty good mileage. The Ranchero is the same weight as the Pinto (2400 lb).
Old 07-01-2011, 07:29 AM   #4 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
The FOB Pinto tunes up lovely- a 1.6 head on the 2.0 block, with some cams and porting = 100bhp/litre.
Search on the UK google site for info- loads of folk doing it
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
