Old 02-01-2010, 08:58 AM   #1 (permalink)
1994 honda civic ex 5 spd
I was wondering if it was possible to use a VX oxygen sensor and VX ECU to get greater gas mileage? If this is possible, where does the 5th wire for the oxygen sensor hook up? I have recently been getting 30-33mpg Highway with a completely stock 1.6 SOHC vtec (172,000miles) with 1996 honda civic HX 5 spd transmission and am in need of better mileage.
Thank you in advance.
Old 02-01-2010, 12:12 PM   #2 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Better mileage is going to be in your head, in your gearing, in your intake and your exhaust as much as it's going to be in the lean burn.
the VX tranny is going to give you better gearing then the HX even but your 1.6L engine most likely has a cam that is giving you lousy low end power and because of that running rich, to match low end power you need a tuned intake and exhaust that is matched to the engines lower speed.
1994 Honda Civic D15 3-STAGE VTEC TURBO 55+ MPG FullRacePhil For Sale 30 03-03-2015 07:05 AM
'93 Civic 40.6 mpg + Harbor Freight utility trailer, Honda CL125, Honda CH80 scoot begreen Introductions 13 08-29-2013 06:37 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Seriously! My 1994 Honda Civic DX Build Thread! JJMunoz EcoModding Central 29 02-18-2012 08:09 PM
For Trade: 1994 Honda Civic VX in North GTA flydude1221 For Sale 1 02-05-2009 03:59 PM
