Old 02-06-2012, 05:56 PM   #1 (permalink)
81rabbitdiesel's Avatar
Location: East Texas, Hill country North of Tyler Texas
DaRabbit - '81 Volkswagen Rabbit LS
90 day: 60.03 mpg (US)
Hi Guys
Hi Guys.
I started Hypermiling a few weeks ago with my 81 rabbit diesel 1.6 na and had some decent results.
416.6 miles used 7.4 gallons or 56 mpgs. these arent hyw miles but the back roads in east texas. Average Speed maybe 40 mpgs, never going over 50 and more often than not onder 40. I started doing engine off coasting this tank. the car has a 5 speed in it and i try to get in it as fast as i can on semi level ground or stay in 4th and just touch the gas peddle for the hilly areas.
I saw where Project Sipster got 84 mpgs with some areo mods and swapping the engine. Im wondering if i do the areo mods but no engine swap how high this thing might get. im no speed demon and am never in a hurry so hopefully someday we will see.
My first mod i think will be a full belly pan. i have an cow feeder on the property that has enough galvinized sheet metal on it to cover the belly. I think this will help a bunch since the back end of the rabbit undderbelly can catch a LOT of wind the way its designed.
Looking forward to reading more and learning more from the sight.
Thanks for reading, Don
Old 02-06-2012, 06:42 PM   #2 (permalink)
'10 Kia Forte EX 2.0 - '10 Kia Forte EX
90 day: 37.29 mpg (US)
Welcome.
The gains from mode will vary, but they do add up. Smooth wheels and grill blocks are two others you can pretty easily manage that will net you some decent gains. Also, don't forget inflating your tires to the max side wall or even over inflating if you feel comfortable.
Old 02-07-2012, 11:35 AM   #3 (permalink)
Thanks Jsatter,
The Tires on the car are 155 80 r 13s pumped up to 60 psi. the max sidewall rateing is 44 : )
I will get to work on the grill block. though im not sure how long that would be usable here in East texas were probably a month or 2 from the 100+ temp days again.
Thanks, Don
Old 02-07-2012, 04:51 PM   #4 (permalink)
JediSpam's Avatar
The TSX - '08 Acura TSX
90 day: 33.06 mpg (US)
welcome. i'm from east texas
Old 02-12-2012, 05:00 PM   #5 (permalink)
Hi Jedi,
looks like we have a few east texas hypermilers on the sight. A lot to learn and have fun with.
Thanks Don
Old 02-12-2012, 07:48 PM   #6 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
I managed to get a low '70's mpg once on a trip eastbound in western Kansas w an
'82 Quantum wagon w the same motor as yours.
I regularly got 52-57mpg on roads trips at 50-55 mph. I never got below 46mpg commuting
(admittingly 3/4ths freeway), and still go 32mpg. towing a 200# + bolt together trailer w
a small motorcycle, and bicycle strapped on for a camping trip in the mountains.
Keep up the good work. Is yours a 4 speed, or a 5?
Old 02-13-2012, 01:23 PM   #7 (permalink)
Hi Larry,
the Rabbit is a 5spd in it.
A friend helped me mount a fuel cut off switch in it a couple of days ago as i was getting worried about burning up the glow plugs useing the key for off engine coasting. Im thinking this will ease my mind and ill do engine off coasting more now. You hitting the low 70s once gives me hope that i might can do the same.
My last tank was 56.2 mpgs with at the most 60 miles of freeway.
I am disabled and havent worked in a long time so most of my trips are within 10 to 20 miles of my house. Doctors, store for food and try to go to my friends once a week just to get out of the house LOL
Hopefully this spring i can get to work on some aero mods to help the rabbit cut through the wind a little better.
Old 02-13-2012, 05:22 PM   #8 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Keep up the good work and start a fuel log so we can keep track of you.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 02-14-2012, 12:28 PM   #9 (permalink)
Thanks Dave,
I got the fuel log done. dont know how to get it on the bottom of my posts but its in the garage part of the site now.
thanks for reading, Don
Old 02-14-2012, 12:37 PM   #10 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Have a look here :
http://ecomodder.com/forum/showthrea...ture-2117.html
It's not mandatory though
