Old 06-26-2009, 12:35 AM   #11 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Ummmm.... humidity hurts FE and robs power from the engine.
This is the only reference I can find at the moment.
"Fog and humidity affect the performance of aircraft. During takeoff, two things are done to compensate for their effect on takeoff performance. First, since humid air is less dense than dry air, the allowable takeoff gross weight is generally reduced for operations in areas that are consistently humid. Second, because power output is decreased by humidity, pilots must compensate for the power loss."
SPECIFIC HUMIDITY
Not only for that reason but it also decrease the specific heat ratio of the combustion gases.
Old 06-26-2009, 09:27 AM   #12 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Not sure on the FE part. Humid air is less dense, like hot, or rarefied, air, that is where the power loss comes in (and usually where the FE gains)
Originally Posted by Christ View Post
So what if I just inject steam into the intake? (Steam, scavenging heat from exhaust.)
It is an interesting thought, would like to know myself.
Old 06-26-2009, 11:21 AM   #13 (permalink)
DieselMiser
ConnClark's Avatar
"High air humidity decreases the thermal efficiency and, thus, reduces the engine mean effective pressure"
http://www.scielo.br/pdf/jbsms/v25n3/a10v25n3.pdf
Pumping steam into the intake every now and then might be a good way to clean carbon out which might improve FE
Old 06-26-2009, 11:49 AM   #14 (permalink)
dcb
needs more cowbell
dcb's Avatar
I'm sure I don't know enough about it, and the state of the water is likely a factor as well. But there have been reports of improved mpg with (a very well tuned) water injection though.
WATER INJECTION WIZARDRY
Of course it is not at all the same mechanism as HAI or high altitude driving. I think it is more akin to that 6 stroke thing that squirts water in on one of the strokes (it is basically %50 steam engine).
Old 06-26-2009, 01:55 PM   #15 (permalink)
DieselMiser
ConnClark's Avatar
People have also claimed FE improvements using acetone and HHO systems despite evidence to the contrary. I will admit that water injection can show FE improvements but it only really comes into play at full load. Also FE gains resulting from water injection are usually less than 5% .
Water injection is different than high humidity. As the mist evaporates it cools the air which results in more mass trapped in the cylinder on the intake stroke. Assuming the use of EGR those two factors mean less heat loss to the engine block during the power stroke. The end result is more power in the output. High humidity alone just thins the air.
Old 06-26-2009, 03:08 PM   #16 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
SPECIFIC HUMIDITY
Increased humidity (and air temperature) increases the density altitude seen by aircraft operating under those conditions. An increased density altitude means the aircraft is operating as if it were at a higher altitude than it actually it. In other words, an aircraft taking off from a runway at 1000 ft elevation when the density altitude is 1800 feet will perform as though it were at 1800 ft elevation. Pilots have temperature/humidity tables they can use to calculate density altitude, which they add or subtract from their actual elevation. As altitude increases, the stall speed increases (but not the indicated airspeed), which increases takeoff and landing distances. Also the power output of normally aspirated piston engines is reduced, further, increasing the takeoff distance. This is why they reduce the gross weight as mentioned mentioned above. But, provided their air-fuel mixture is leaned properly, a normally aspirated piston engine will burn less fuel while operating under higher density or actual altitudes
aerocivic.com
Old 06-26-2009, 03:45 PM   #17 (permalink)
dcb
needs more cowbell
dcb's Avatar
... comes into play at full load...
...Like your typical P&G hyper-miler would use. So if your average idiot gets %5 improvement...
Old 06-26-2009, 03:58 PM   #18 (permalink)
The reduced aerodynamic drag at altitude is the only effect on you'll notice on FE. You still require the same amout of fuel and oxygen to generate 100hp at 15,000 feet as you do at sea level. The only difference is at the lower air pressure you'll require less HP to reach and maintain a specific speed.
Old 06-26-2009, 04:28 PM   #19 (permalink)
dcb
needs more cowbell
dcb's Avatar
plus the fact that the throttle might be open wider, so less pumping losses.
Old 06-26-2009, 05:43 PM   #20 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Ok, so now I'm confused... using steam to lower effective displacement will work, or no?
I know about water/meth injection, but it doesn't really apply to our situation, I don't think?
What I'm looking for is if I circulate water around the exhuast pipe to heat it up, then inject it into the intake as steam, will it work to reduce effective displacement, and help to cool the engine while one is burning a lean mixture? (I mean REALLY lean, like 17-19:1)?
Could a diesel benefit from steam injection?
altitude
Why the Civic VX is a superior highway fuel economy (FE) machine MetroMPG General Efficiency Discussion 9 10-10-2010 05:26 AM
Driving the Scanguage for FE Harry6 Hypermiling / EcoDriver's Ed 12 04-02-2010 12:51 PM
Skeptical of "blade" exaust tip FE / emissions claims Cd EcoModding Central 42 01-14-2010 10:44 PM
How Many Automatics out There? (FE techniques discussion) RH77 EcoModding Central 18 02-07-2008 10:50 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
