Old 08-31-2022, 03:18 PM   #1 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
High temperature insulation of engine hoses
My (230V AC) electric engine prewarmer had to be installed on the coolant hose going from the cabin's heating core back to the engine block, wouldn't fit anywhere else.
How beneficial it would be to insulate the hoses going between the cabin and the engine? I am thinking about how much heat they radiate when the engine bay's temperature is below freezing. The insulation may allow slightly faster heating of the engine, or higher prewarming temperature.
What kind of insulation would be best for this? It must withstand relatively high temperatures from the engine block, but also not be affected by low temperature nor moisture.
The Following User Says Thank You to Piwoslaw For This Useful Post:
101Volts (09-05-2022)
Old 08-31-2022, 04:48 PM   #2 (permalink)
Very beneficial. For all the reasons you listed.
Pipe insulation.
Hot water or HVAC
Cheap and effective.
Don’t forget to add a engine blanket if you’re not already using one.
Edit;
Check manufacturers specifications regarding working temperature as there can be wide variances between materials. ( closed cell foam, Nitrile, silicone, etc.)
HVAC and solar heating pipe insulation seem to have working temperatures
between -40 to 150 C.
Donald J Trump 8/21/21
Disclaimer...
But...
I play one on the internet.
The Following 2 Users Say Thank You to redneck For This Useful Post:
Isaac Zachary (09-01-2022), Piwoslaw (09-01-2022)
Old 09-01-2022, 10:14 AM   #3 (permalink)
High-temp insulation
A look at the 'Commercial' products may reveal something useful.
In 1986, I was involved with a steam/hydronic heating system for the American Airlines headquarters building in Bedford Euless, Texas.
All piping was wrapped with Knauf products.
https://www.knaufnorthamerica.com/en-us
