Old 12-03-2009, 07:33 AM   #1 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.64 mpg (US)
Water pumps
Has anyone ever done an A-B-A on the water pump drag? I'm currently working on ways to heat my Ninja up, and a water heater won't work because I can't get on the low side of the engine, unless I bypass the water pump.
So this got me to thinking about the drag the pump represents, and the potential for going with an electric pump, if I can find one.
Old 12-04-2009, 12:15 AM   #2 (permalink)
There is an Australian company named Davies - Craig who make electric pumps and cooling fans.
Details at:
Davies Craig
Good luck , Pete.
Old 12-04-2009, 11:16 PM   #3 (permalink)
Details at:
Davies Craig
Good luck , Pete.
Aww, they make the exact thing I could use, and it's above my price range and shipping is murderous.
Old 12-05-2009, 01:11 AM   #4 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
How is the pump normally driven? Maybe we can come up with a DIY solution...
Old 12-05-2009, 01:16 AM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
There are cheap 12v bilge pumps, might be worth seeing how it does with heat and pressure and rig it in:
Whale Orca 500 GPH 12V Bilge Pump Model # BE0500:eBay Motors (item 360213575402 end time Dec-06-09 12:23:41 PST)
You could probably limp home on a slow p&g if it disintegrates
Water boiling dilemma: electric vs nat. gas Piwoslaw Saving@Home 22 01-10-2025 10:07 AM
Water heating using ONLY the pilot light MissileStick Saving@Home 51 06-02-2010 08:55 AM
Electric Water Pumps guudasitgets EcoModding Central 53 12-24-2008 12:27 PM
Water Meter for water savings!!! bennelson Saving@Home 3 12-11-2008 07:21 PM
Hot water from oil in the summer time. Xringer Saving@Home 11 09-06-2008 10:02 PM
